It is currently Wed Jul 23, 2025 9:28 am
PostPosted: Mon Nov 18, 2013 6:05 pm
It should have more than 50psi when cold, I would pack the spring inside the cap, use a small nut..
PostPosted: Tue Nov 19, 2013 9:37 am
Ball seals better when seated, it is hardened and the seat is not, so the seat gets shaped to fit. You get better oil pressure at idle (no leakage). The plunger does not seat well unless it's lapped in, and they seldom are.
There is also the story spread by suppliers and others that the 9/16" ball was used in the Cooper S. I have owned a few S motors over the years and never found one. it may have been a homologated part for competition, I dunno.
I currently use a ball, it works fine when fitted as I described above.
ps. These days I prefer the plunger too. The only thing the ball has over it is it won't get jammed with metal swarf, but if you have swarf circulating you have bigger problems.
Well now I am confused :? :roll:
CF
PostPosted: Tue Nov 19, 2013 9:42 am
I still have the ball in mine, but I won't use them in any motors I build in future. :wink:
PostPosted: Tue Nov 19, 2013 9:46 am
phillb wrote:
Might be worth trying a different gauge also.
especially if the car is not running hot :arrow: :idea:
