It is currently Wed Jul 23, 2025 6:13 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 11, 2005 7:33 pm
I use Loctite (yes, it was Permatex) #3 aviation gasket cement on most paper gaskets, but for the diff gaskets I use Loctite 515 master gasket.
Head gaskets use nothing, unless it's a POS copper one- then I use Loctite 515 along the front around the water holes.
The Loctite 515 is an anaerobic sealer, (sets in absence of air) used for metal to metal seals. Good for air-oil-fuel-steam. I've built a few boxes with no side cover gaskets, just this stuff. It is good crap. $18 a tube though.. :shock:
I don't like silastic- it goes everywhere if too much is used- which people do- and can plug oilways etc. I've heard of water pump bolts pinging metal off #1 cylinder bore because silastic got in the hole and when tightened up, it hydraulicked the block...
PostPosted: Wed May 11, 2005 10:26 pm
One thing I never see mentioned is using an high temp anti seize grease on all exxhaust and manifold bolts ans also where a steel bolt goes into aluminium. Makes dis-assembly so much easier. Put it on all exhaust pipe joints and they will always come apart a lot easier.
Chris
Everything I like is either
PostPosted: Wed May 11, 2005 10:35 pm
Well....As Dr will rember...When we purchased Morris..The PO used Gasket Goo on the head Gasket and it blocked the water well's...so it heated up 1 & 2 Cylinder...
Hay Batman did you hit the fog screan button...
NO :shock:
Rebuild time
Use a God gasket with no Goo PLease :!: :!: :!: :!: :wink:
