It is currently Sun Aug 17, 2025 11:35 am
PostPosted: Tue Dec 03, 2013 8:06 pm
Hey all, I'm looking at getting another mini with a 1275 in it. i was wondering if anyone has tried retrofitting an a/c system into theirs? (im sure there are) I had a rover mini that ran better with the a/c on cause the extra fan kept the engine cool. lol
But I was wondering if any of you have first hand experience on the older ones? and if any of you have suggested places to do it in Sydney or Canberra
PostPosted: Tue Dec 03, 2013 8:22 pm
There's no reason you couldn't fit a small under dash unit and basicly copy the rover set up for the engine side of things. I've fitted units to MGs and E types, both have limited interia space. You can also do smal mod to SU's to add idle up circuit. I sold the a/c out of mine to a guy who fitted it to an early mini.
PostPosted: Tue Dec 03, 2013 8:25 pm
Just hunt around mini wreckers and see if you can find a pre-96 setup. Before '91 would be better as the wiring is simpler.
PostPosted: Wed Dec 04, 2013 7:20 am
Wouldn't it be easier to put a 60's grill on a 90's mini?
PostPosted: Wed Dec 04, 2013 8:02 am
:/ a little off topic?
in SA there was a leyland with rover a/c retro fitted with full rover interior, so yes id say its entirely possible to fit they had the condensor behind the grille
PostPosted: Wed Dec 04, 2013 12:48 pm
I suppose one of the troubles is where would I position the vents in the cabin. lol
but then again, with it being so small I'm sure just two vents hidden on both sides should suffice. Now to try and find an A/c system!
PostPosted: Wed Dec 04, 2013 1:26 pm
The units up to about 91 are under dash, so you could fit them in any Mini with only a few extra holes drilled in the shell.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: No registered users and 390 guests
