TK wrote:
Tell us more about your set up Kev. Pics?
Ty, I have pics but can't put them up right now, they are on my old PC (which is offline) and I've just this week gone Mac...
I will try to bung them up on flickr tomorrow.
There is a thread here in chat somewhere already with pics if you want to try a search.
The sensor is mounted 3" from the end of an 8" long length of 1" OD steel pipe, which gets clamped into the tailpipe.
The standard sensor cable supplied will reach from the front seat, out the rear side window and down to the sensor.
The downside to mounting it here is you cannot get an idle reading due to the in & out gas flow, but once you give it any throttle when driving it reads fine.
I fitted a 2.5M length of 2 core flex for power supply, two alligator clips hook onto the battery. I run the cable out the boot and up over the LH fuel filler, a cable tie round that holds both the sensor cable and power lead in place so you can drive at any speed.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
