It is currently Tue Aug 12, 2025 11:13 am
 Post subject: Slow and dim
PostPosted: Fri Dec 06, 2013 7:57 pm
The subject isn't a description of me by the way. Quick one for you tech experts. I got my indecators to work but the left side ones are dim and slow when coming on I have the correct bulb in
Any ideas?
Rob M
Black is the new Black
 Post subject: Re: Slow and dim
PostPosted: Fri Dec 06, 2013 8:05 pm
Bad earth perhaps ?
PostPosted: Fri Dec 06, 2013 8:10 pm
Are both indicator bulbs working when you put your indicators on?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Dec 06, 2013 8:12 pm
I had a heap of trouble with my indicators just this week, they were slow, and my stalk light wouldn't work.
Cleaning the fuse box with some contact cleaner, and replacing the flasher can with a $7 generic three pin one fixed them right up.
If it's only one side and all the bulb wattages are the same I'd say it must be a dirty connection or a bad earthing point. I'd try fiddling with the nuts on the back of the tail light on the side that is slow first, the rear indicator earth is through them. I don't know where the front indicator earth goes, it's a wire into the loom
PostPosted: Sat Dec 07, 2013 5:02 pm
Cheers guys I will check the earthing and let you know how it goes
PostPosted: Sat Dec 07, 2013 5:08 pm
The front ones do have earth wire but also earth through mounting screws.
Users browsing this forum: Google [Bot] and 355 guests
