It is currently Fri Jul 18, 2025 11:46 am
PostPosted: Mon May 27, 2013 4:03 pm
thought i would throw this in here.
http://bonnevillestreamliner.com/2000cc-v8-engine/
GSXR 2000 engine (ie 2 gsxr 1000cc engines making a V8), given the weight of the minis the largest engine we can swap is either 1.4L forced induction or 2.0L NA, this would given you close to 400hp (depending on year models) and be about the same weight as a mini engine. i know its been done with the hayabusa motors but they would be to big to fit.
Also for anyone looking for an answer to the age old question of how to make a revers gear, saw this the other night, this seems cheap compared to others that are available, small enough and gives a rating of 400hp.
http://thekneeslider.com/reverse-gearbo ... stercycle/
anyone else thought about doing something likes this?
PostPosted: Sun Dec 08, 2013 7:43 pm
At the BMC experience show today.
Pro Motive kit. Dad building it. Son owns it. Only has to pass brake test to complete engineering approval.
PostPosted: Sun Dec 08, 2013 9:38 pm
well there you bloody go then!
looks like dad's doing a very tidy job, even keeping the heater!
PostPosted: Sun Dec 08, 2013 11:22 pm
It was drool worthy. Very tidy inside and out.
 Post subject: Re:
PostPosted: Tue Dec 10, 2013 5:30 pm
I've though about this in the past and wondered why no one had done it yet, but have they spun one engine around 180 deg? If so won't the cranks be running in opposite directions so how would you connect them :?: :?
PostPosted: Tue Dec 10, 2013 7:10 pm
If you look at the pictures of that twin gsxr engine the crankshafts are going opposite ways so the central shaft is driven the same way. And doing this you can't use the bikes gearbox so there goes the simplicity of using the bike engine.
PostPosted: Tue Dec 17, 2013 9:45 pm
Amazing!
Cheap option for a nice swap
PostPosted: Tue Dec 24, 2013 4:38 pm
Cheap option? I would hate to see the cost of an expensive one.
PostPosted: Thu Dec 26, 2013 8:23 am
He must mean in the front , rather than in the rear with all the custom fab required ?
