It is currently Mon Aug 18, 2025 12:14 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 13, 2013 1:11 pm
Mick wrote:
Certainly can cause the contacts to fail, and this does happen. Can you see the 12 volts getting through the relay to the output side? If there is 12 volts on the out put, then it is a downstream issue.
yep, the next point of call is taking out a headlight to try to see whats happening on the other side of the relay.
3 hours till the kids get home from daycare, and i still have to mow the lawn.... RDO's are too short!
1975 Hairy Lime/White Clubby
PostPosted: Sat Dec 14, 2013 6:52 pm
Finally figured out the highbeam problem today, ended up being a faulty wire... took about 2 minutes to fix once i'd figured it out.
at least I learned alot while I was poking around!
here is the offending wire... all 20 centremeters of it...
I cut it open, seems like when it was crimped, it was compressed so much it broke all the wires at one of the crimps.
PostPosted: Sat Dec 14, 2013 7:33 pm
Good work - persistence pays off.
Users browsing this forum: No registered users and 126 guests
