It is currently Fri Aug 22, 2025 12:00 pm
 Post subject: Windscreen rubbers
PostPosted: Wed Dec 18, 2013 10:42 am
So while I was on exchange over in Europe I bought new mini rubbers for my leyland, and as it turns out they are both the same shape and size, so I think they are both front ones?
Bit of a mistake from the sellers end ...Well, I can't do anything now, so does anyone have a spare rear windscreen rubber to straight swap for my spare front one? I don't really want to cut it to size and ruin it.......
Im in Adelaide
Thankyou!!!
 Post subject: Re: Windscreen rubbers
PostPosted: Wed Dec 18, 2013 11:48 am
pohmy rear screens are much bigger than Aussie (original) ones
PostPosted: Wed Dec 18, 2013 12:13 pm
That's interesting, never realised.....bummer. Well yes the offer/swap still stands, the rubber is suitable for front windscreen. It's brand new, so if I can get $60 for it, might put it in for sale section.....
PostPosted: Wed Dec 18, 2013 12:35 pm
The ones I bought for mine were the same size I think. And I needed to cut both down anyway.
So it didnt really make any difference.
Dusk Blue
1964 850
PostPosted: Wed Dec 18, 2013 12:43 pm
Oh really? could you tell me how you did it exactly? what happens where you join it together? Some sort of rubber glue?
We did an 850 couple years back, didnt need to cut anything down.....
PostPosted: Wed Dec 18, 2013 12:52 pm
Cut the ends clean, use Selleys Superglue.
PostPosted: Wed Dec 18, 2013 12:58 pm
yep, it`s pretty common & not a problem at all
PostPosted: Wed Dec 18, 2013 1:02 pm
And where do you recommend putting the actual join in relation to the window frame? Top or on bottom?
Also put the chrome insert strip ends with joiner in the same spot or on opposite side?
PostPosted: Wed Dec 18, 2013 7:07 pm
When I cut my windscreen rubber I cut the straight and a bit longer than you think because you don't want it to be too short once the windscreen is in I put both the locking strip join and windscreen cut in the same spot at the top.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
