It is currently Thu Jul 24, 2025 10:34 am
PostPosted: Wed May 11, 2005 10:59 pm
Stuwey_LS wrote:
Huh? Remove rad first? what are ya, bloody stupid?
I meant remove the radiator before taking the engine out.
Ya cant just take it out. well ya can but its pretty hard. and you'd break things :wink:
 Post subject: .
PostPosted: Wed May 11, 2005 11:03 pm
There is no need to remove the rad. it comes out with the motor.:D
PostPosted: Wed May 11, 2005 11:05 pm
hehe and u say that bit about taking out the front bar bit that the bonnet closes down onto...
I once saw a mini mechanic in Kent Town (and shall remain unnamed) just lift the engine upupupupup till it cleared enough, then he brought the engine crane away from the car and it bent the piss out of it coz the extractors caught on it.
Derr! :roll: :lol:
PostPosted: Thu May 12, 2005 6:56 am
2 S's & a clubman wrote:
If you captive weld your nuts to the engine mounts, they can be undone in 10 seconds, it's the 1st modification you should do to a mini.
Doogie
I'm with Doogie, after you do this mod the rad can stay on the motor and you just lift it all straight out.
Helps if you have a lifting bracket bolted on the head, that allows this.
I take the Maniflow LCB off, because the Y piece is rusted to one of the downpipes... :x
Users browsing this forum: timmy201 and 104 guests
