It is currently Thu Jul 03, 2025 2:07 pm
 Post subject: discs on rear end
PostPosted: Fri Dec 20, 2013 7:59 am
I've got 7" cooper discs on rear of my mini [don,t ask] any body got ideas for a hand brake set up ?
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
 Post subject: Re: discs on rear end
PostPosted: Fri Dec 20, 2013 8:37 am
hydraulic handbrake or the tiny willwood mechanical calipers
PostPosted: Fri Dec 20, 2013 4:58 pm
go-kart caliper + cable + bmx lever + drift spec cable tie lol
PostPosted: Fri Dec 20, 2013 9:47 pm
Sorry... I have to ask... KAD kit? Or is this something you have engineered...? Can u adjust the brake bias.?
PostPosted: Sat Dec 21, 2013 6:11 pm
honda civic/crx caliper - integral handbrake and fits under a 10" mini wheel
PostPosted: Sat Dec 21, 2013 10:01 pm
Hmmm, sounds like a lot of effort for little gain... definitely lighter and would look cool...
PostPosted: Sun Dec 22, 2013 3:41 pm
something i,ve engineered. have minispares adjustable valve
PostPosted: Sun Dec 22, 2013 8:35 pm
You could fit an electric brake lock. Fits into the hydraulic line and works via a 12 v actuator. From what I understand you flick a switch and apply the brakes... The brake lock act as a one way hydraulic valve, therefore holding pressure in the circuit after you take your foot off. There are a number of companies. Maybe try mico.com, not sure of cost but probably not too expensive.. Anyway... That's what I would do
PostPosted: Sun Dec 22, 2013 9:01 pm
Line lockers and hydraulic handbrakes are not legal as parking brakes for road use. (but line lockers are very effective anti theft devices)
PostPosted: Wed Jan 01, 2014 10:17 am
i,ll chase up the honda option ,any help with appropriate mods would be helpfull
PostPosted: Wed Jan 01, 2014 12:09 pm
Can we find out why you chose to use Cooper disc brakes on the rear? and a pic please?
PostPosted: Tue Jan 07, 2014 4:19 pm
the car has an engine in the boot [there are photo,s on this site at recent mini show, brg car ] cooper 7" setup is slightly narrower than 7.5". i,ll put some photo,s up when i work out how.i,m told the car was on fletch,s program dunno how much detail is visible
PostPosted: Tue Jan 07, 2014 4:26 pm
I loved that car. It must go like stink!
PostPosted: Sat Feb 01, 2014 10:57 am
I have recollection of hearing about a twin engined moke the military used on carrier platforms.
It's easy once you know how.
PostPosted: Mon Feb 03, 2014 5:59 pm
yeah me too,probably had drums which would make h/brake easy,but engineer is saying discs, wondering if honda caliper could be adapted to mini swivel hub ,has anybody tried?
