jubblies wrote:
Excellent. Thanks all for the info.
I gathered it was the drivers seat, that way you flick the catch from outside the car.
The tops are barely there. Looks pretty pic the bits that are left. Thus black vinyl with 6 pleats from the top to the base.
I thought they pre-dated the rubber diaphragm. Very interesting. Maybe a $$ saving thing in the factory?!
Thanks for the info.
If The pleats are almost the same width as each other, You can be reasonably
sure that they were fitted to the Base Mini,
On the base model Mini the trim is thinner than the other models
If You are able to have a look at what is left of the trim,
try a little test If You cannot stretch the material easily in the areas that You sit
on it is the base Model Mini, The Grain Pattern on The seat in the Photo
is the same as the Mk2 Cooper S. and is correct for this period.
Re The seat base It Is My understanding that this type was tried
as they did have some problems with the Rubber Type,
But the spring and wire type caused more complaints, It is also my understanding
that most of these complaints were from a major customer, The NSW Police
And to answer Bubbacluby The Round Nose Mini with lift up door handles
had this type of seat fitted,
You can take that to the Bank, If you get the chance have a look underneath
a Roundie with lift up handles and you will see a extra bracket welded to the
floor, To hold the bracket that the catch clips on to the same as Your Clubman GT
