It is currently Sun Aug 03, 2025 12:51 am
PostPosted: Mon Jan 06, 2014 3:41 pm
Milatsmadmini
Anyone have a spare? :(
PostPosted: Mon Jan 06, 2014 5:16 pm
Is that a 1275 one? Are they the same as 998 type?
PostPosted: Mon Jan 06, 2014 5:19 pm
998 and 1275 are different only in the hole placement, quick fix with a 5/16 drill bit :) nice over flow bottle 8)
PostPosted: Mon Jan 06, 2014 5:37 pm
When you remove it check the bulkhead to make sure it's not cracked between holes as well.
PostPosted: Mon Jan 06, 2014 5:40 pm
Check this out:
MiniSport
http://minisport.com.au/prod173.htm
PostPosted: Mon Jan 06, 2014 6:49 pm
Pretty sure there is one here.
Come get it. :wink:
PostPosted: Mon Jan 06, 2014 7:21 pm
The Mini King
When You replace it Get an old brake pedal bracket, Minus the pedals
cut the nose part off then bolt in place, this will Go a long way to stop
the bulk head cracking, Also only use rubber bushes they ar a lot kinder to
the bracket and the bulk head
PostPosted: Mon Jan 06, 2014 10:59 pm
Milatsmadmini
Come get it. :wink:
Taking you up on that one.
when is suitable?
PostPosted: Tue Jan 07, 2014 10:54 pm
I'm around tomorrow.
