It is currently Sat Aug 09, 2025 5:58 pm
 Post subject: Mini Horn Help?
PostPosted: Thu Jan 09, 2014 9:04 pm
Hi I'm putting my mini on club rego on Saturday but it has no horn the wires have been put in when the harness was made. I attached the horn to the wires
The Purple wire near the steering column where should that go? If I touch the steering Column with the purple wire the horn works but stays on
the car has a original deluxe steering wheel which the push button may be set up wrong on the column?
any help would be great thanks
 Post subject: Re: Mini Horn Help?
PostPosted: Thu Jan 09, 2014 9:15 pm
12 volts comes from the fuse, through the horn and up to the steering column. The 12 volts is grounded to the steering column when you press the button causing the horn to sound.
You have everything fine up until the column. The purple wire should enter the column to go up the center to the horn button under the steering wheel center. It is at the button that the horn is grounded to the column. It jumps the gap to the rotating column via a copper slip ring and brush. Check to see that the brush and slip ring is connected to their respective wires. Try grounding manually at the top of the column as well.
PostPosted: Thu Jan 09, 2014 9:20 pm
The purple wire hooks to the blinker switch wires and makes contact with the column at the slip ring
PostPosted: Thu Jan 09, 2014 10:45 pm
Thanks for that I reckon that will be it
PostPosted: Thu Jan 09, 2014 10:59 pm
Where are you getting it inspected mitchell, I need to put a few of mine on club reg.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Fri Jan 10, 2014 8:43 am
Jason I guy in north Yunderup he has been used a fair bit for the sdmc
bit far for you but ask Christine she has a list of the people you can take it to
PostPosted: Fri Jan 10, 2014 9:42 am
Will do thanks mate
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Jan 11, 2014 10:23 am
Did you get the horn sorted mitch?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sat Jan 11, 2014 4:33 pm
All sorted now and on club rego
Users browsing this forum: Bing [Bot], watsupskip and 94 guests
