It is currently Mon Jul 28, 2025 9:21 am
 Post subject: Clicking on a topic.
PostPosted: Sat Jan 11, 2014 6:01 am
Why does it always take sever Clicks to open a topic on this forum? I am hurting my Mouse !
"Let us remove your "SHORTS"
 Post subject: Re: Clicking on a topic.
PostPosted: Sat Jan 11, 2014 6:50 am
Is your mouse ok - as in is the left mouse button ok? One way to test is to click a link with the right button, open a new tab /window, and see if it registers first go.
But I'm asumming it does this with all links...
PostPosted: Sat Jan 11, 2014 6:52 am
Give Ash some flowers Nick .
Mine works fine.
PostPosted: Sat Jan 11, 2014 8:18 am
mine is fine
PostPosted: Sat Jan 11, 2014 2:54 pm
Not had that problem. Any more details on your setup, ISP, etc?
michael
PostPosted: Sat Jan 11, 2014 3:42 pm
My little mouse fine too...take yours to VET?
PostPosted: Thu Jan 16, 2014 7:54 pm
Is the hampster having trouble with the heat ?
I'm having trouble getting connected , opening threads , changing and getting out of pages , taking upto 30 - 60 secs sometimes ,this is an intermittent problem which has only been going on for the last 2 days .
Anybody else having issues ?
I am not having any issues with some other regular sites that i usually get on , first up i thought it might of been my computer .
PostPosted: Thu Jan 16, 2014 7:59 pm
Yep, I'm just about fed up with it again.
PostPosted: Thu Jan 16, 2014 8:01 pm
i was getting a message from "www.opendns" saying ausmini server is having problems, is it the heat? give the hamsters some water
PostPosted: Thu Jan 16, 2014 8:04 pm
To All, try ALT T, tools menu open. Select the compatibility view settings option and then add Ausmini.com.au to the list. You will need to sign out of Ausmini.com.au and then sign back in.
PostPosted: Thu Jan 16, 2014 8:44 pm
There has been a problem today. I've had all kinds of issues just getting onto the forum, let alone the forum software.
I've put a job in to the server hamster wranglers.
PostPosted: Thu Jan 16, 2014 10:15 pm
I keep getting a "Chrome can not find this page, try to refresh" message. Sometimes from clicking a topic, sometimes from trying to log in. Sometimes it works flawlessly though. It seems pretty hit or miss - either I'll have no problems and everything will load instantly, or it'll pretty much all fail.
PostPosted: Thu Jan 16, 2014 10:24 pm
I have been having access problems for days. Using iPhone it just hangs and needs more clicks or a previous page then go forward again. PITA
PostPosted: Fri Jan 17, 2014 12:10 pm
yep I'm having the same problems
PostPosted: Fri Jan 17, 2014 1:16 pm
Ausmini needs more money?
Users browsing this forum: No registered users and 59 guests
