It is currently Sun Aug 10, 2025 2:31 am
 Post subject: at a cross road
PostPosted: Tue Jan 14, 2014 7:25 pm
Hey guys
I am at the point of removing all the paint from deluxe and have discovered that at one point it has had a front end collision.
Now the panel beating work done is pretty impressive but would still require a layer of body filler to flatten out.
I have spent countless hours and over $1500 on new panels to eliminate rust.
Now my question is do I repkace the front rh gaurd and front panel or do I do just put a layer of body filler on again which looked just fine before.
The car isnt going to be concourse or anything close to that but im just not sure how much more I can justify spending on body panels
Cheers guys
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
 Post subject: Re: at a cross road
PostPosted: Tue Jan 14, 2014 7:34 pm
I would replace them. I regret not replacing mine as the alignment is just not right. its close, but not right.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Jan 14, 2014 7:36 pm
Score 1 to replace 0 to retain...
First to ten wins...
Then someone has to convince the cook....
Minis..
1975 van
PostPosted: Tue Jan 14, 2014 7:46 pm
9 for replace then
PostPosted: Tue Jan 14, 2014 7:55 pm
There was some new unused on Gumtree last week may be a option .
PostPosted: Tue Jan 14, 2014 8:01 pm
Yeah just looked on gumtree cant see the ad
Minis..
1975 van
PostPosted: Tue Jan 14, 2014 9:25 pm
Think it was in Booragoon , may be bloke with CooperS bootlid but not sure if its him ,
PostPosted: Tue Jan 14, 2014 9:42 pm
Cheers craig. Sent him an email.
Minis..
1975 van
PostPosted: Wed Jan 15, 2014 1:01 am
bogs not that bad! if your panel beater checks the bonnet fitment and does his job, then it should be a perfect gap around the bonnet, and bog would only be a worry if your filling a huge dent but front guards on minis have plenty of room to swing a hammer, if your paying for it say you want it dead straight! fussy customers win when it comes to panel beaters.
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
Users browsing this forum: Bing [Bot] and 97 guests
