It is currently Sun Jul 27, 2025 7:38 am
PostPosted: Sun Jan 19, 2014 9:51 am
Hi guys, can anybody put up some pics of a firewall mount, trying to make a decision on how to fix mine....
If the bracket is meant to be 90° I might make a new one out of some thicker angle and either spot weld or bolt it in place of the old, other wise I may have to weld this tab back on
'63 850/1100 + more cooper goodies
PostPosted: Sun Jan 19, 2014 12:44 pm
I would bolt it all together with the dogbone's spacer in for alignment, then MIG weld it back on.
Clean ALL the paint etc off the weld area, first.
PostPosted: Sun Jan 19, 2014 12:47 pm
Might that damage the rubber bush?
PostPosted: Sun Jan 19, 2014 12:49 pm
Leave the rubbers out, you just want the spacer + bolt in it.
PostPosted: Sun Jan 19, 2014 12:51 pm
Yeh just pulling it apart now, the bar is fairly bent too
PostPosted: Sun Jan 19, 2014 12:52 pm
PostPosted: Sun Jan 19, 2014 12:55 pm
I believe the bracket is available new from minisport
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Jan 19, 2014 3:48 pm
Far from my best welding and sure isn't pretty but it will do for now
Thanks guys
PostPosted: Mon Jan 20, 2014 4:03 pm
I would just add a bit in the middle on top.
PostPosted: Mon Jan 20, 2014 4:17 pm
I can't get the stud to come on mine. Anyone had this happen before?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Jan 20, 2014 4:18 pm
What do you mean exactly?
PostPosted: Mon Jan 20, 2014 4:42 pm
Sorry, I should of explained that better, and actually read what I typed before clicking submit.
The stud that runs through the spacer and and the two brackets is stuck. I have tried knocking it out with a hammer but it just won't budge.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 20, 2014 4:54 pm
It won't go through, you will have to undo the top bracket =( I will have to do the same to get it back out/put the steady in
PostPosted: Mon Jan 20, 2014 4:58 pm
Callin wrote:
I won't go through, you will have to undo the top bracket =( I will have to do the same to get it back out/put the steady in
As in remove the master cylinders?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 20, 2014 5:00 pm
Yeh, I'm not totally sure how much its gotta be pulled apart though
