It is currently Wed Jul 23, 2025 7:16 pm
PostPosted: Sun Feb 02, 2014 10:21 pm
You will be able to wrap over the scoop no problem
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Feb 02, 2014 10:26 pm
Wouldn't the extra surface area make the stripe go in and therefore look as if they go in thinner?
PostPosted: Sun Feb 02, 2014 10:36 pm
Where did you get the scoop from?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Feb 02, 2014 10:45 pm
www.spoilershop.com.au/
I got both the scoop and Cosworth vents from The Spoiler Shop here in Perth. The guy can fit and paint but where's the fun in that?
PostPosted: Mon Feb 03, 2014 2:27 pm
I would say to use the wrap. I've used it on a few bits and pieces and it's not that hard to get the hang of. And if you stuff it up, you just remove it with a heat gun. As for laying the stripes, I reckon you'd go pretty well using the knife tape http://www.knifelesstechsystems.com/
Basically it's a tape you lay down, it has a little string pull on it which cuts the vinyl wrap. So you lay out your pattern with the tape, wrap over the top, cut with the string, remove left over tape and wrap, and stick down the edges. Gutters etc might get a bit a tricky but it's doable.
Keels.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Mon Feb 03, 2014 2:50 pm
I love stripes on Minis.
Here's mine.
:D
Julie.............
PostPosted: Mon Feb 03, 2014 4:10 pm
Kyoda - I love it, running the stripes inside down the dash I'm so copying that one (if you don't mind?).
Did you paint it yourself?
Great colours too :D
PostPosted: Mon Feb 03, 2014 4:14 pm
Cheers WasabiPimpNinja, great link I'll look into for sure :D
PostPosted: Tue Feb 04, 2014 11:54 am
My husband and a friend painted it at home.
All satin black, including the bright work.
Copy away with the stripes on the dash. It's always one of the first things people comment on.
BTW These are vinyl stripes, not painted.
Julie.............
Users browsing this forum: drmini in aust, Google [Bot] and 92 guests
