It is currently Fri Jul 18, 2025 11:55 am
 Post subject: Timing Question
PostPosted: Mon Feb 03, 2014 3:41 pm
Heya,
I'm going to a mates place in a few days to use his timing light to redo the timing,
I just wanted to know if it matters what RPMs the engine is idling at when we set the advance.
The manual I have says my 998 needs 10 degrees advance at 500rpm.
Currently i've set the idle higher than that (around 900) as i've been told that the higher idle will keep the oil moving around the engine a bit more.
I've tried lowering the idle, but it gets quite rough if it slow it down by even half a turn on the idle adjustment screw
Thanks
1975 Hairy Lime/White Clubby
 Post subject: Re: Timing Question
PostPosted: Mon Feb 03, 2014 3:50 pm
I ignore the idle setting, and do it @ 4000rpm when the advance is at max. Most Minis like it around 30deg total (check with vac advance hose disconnected if fitted). Total advance is way more important than what it happens to be at idle or static.
After 40+ years, most old dizzies are nowhere near their original spec, and the fuel is different now too. No more 97 octane leaded super...
It is too easy to get too much total advance (and burn pistons) if you just rely on static settings.
[edit] I use a dialback timing light, it just needs a TDC mark to work. I dial in 30 degrees and move the dizzy at ~4000rpm until the 2 marks align.
PostPosted: Mon Feb 03, 2014 5:08 pm
And also with a worn dizzy the timing can jump all over the place when you try to set it at idle.
I use a dial back timing light the way Doc says. So much easier to set and just as easy to take a degree or two of advance out if needed.
1963 Morris 850
