It is currently Wed Jul 23, 2025 7:30 am
 Post subject: Engine greens.
PostPosted: Thu Feb 06, 2014 6:11 pm
Wondering if some kind souls might post some pics of their favourite engine greens. I'm looking to bling Barneys engine bay. To set the tone, I have an alloy rocker cover, will have an alloy radiator and a we've on an anthracite manifold with an anthracite linkage. So which green should go for?
Sent from my GT-I9210T using Tapatalk 2
 Post subject: Re: Engine greens.
PostPosted: Thu Feb 06, 2014 6:19 pm
My choice- Cooper S light green metallic. From Mini King.
Which is what your motor is now, but I found later I used the wrong thinners (acrylic) when I sprayed it, so the colour & gloss is off. :oops: Should have used GP thinners. The paint is spraying enamel, but the old tins back in Mini Car Clinic days didn't say so.
PostPosted: Thu Feb 06, 2014 6:21 pm
Looks like one coat too Doc! :wink:
PostPosted: Thu Feb 06, 2014 6:23 pm
Nope it got a coat of etch primer, then 2 or 3 coats of enamel. Like I said, the thinners was wrong but I didn't realise it.
PostPosted: Thu Feb 06, 2014 6:39 pm
PostPosted: Thu Feb 06, 2014 6:45 pm
PostPosted: Thu Feb 06, 2014 6:51 pm
IMGP0977 by k_green1310, on Flickr
IMGP0975 by k_green1310, on Flickr
This was my 1412 stroker, this green is what Greig Malaure uses on some of his engines.
I have the tin here but cannot read the code.
PostPosted: Thu Feb 06, 2014 7:03 pm
It's a bit light for mine. Here's one from the previous owner...
PostPosted: Thu Feb 06, 2014 7:18 pm
Cooper_Matrikon wrote:
This one looks awesome
PostPosted: Thu Feb 06, 2014 9:23 pm
this ones better....more carbs.
PostPosted: Fri Feb 07, 2014 9:34 am
Was the aluminium painted from the factory when new? And was the generator ,starter motor etc painted black our the same colour as the motor?
Present
- 1968 Morris Mini Deluxe- resto
-1979 Leyland Moke
-2007 R56 MINI Cooper
Past
-1964 Morris Mini Van
-1965 Morris Mini Van
-1961 Morris Mini 850
PostPosted: Fri Feb 07, 2014 9:42 am
Morri68 wrote:
Was the aluminium painted from the factory when new? And was the generator,starter motor etc painted black our the same colour as the motor?
Yes, same as the motor- 1 colour all over.
The black starter and generator were fitted, then the whole lot got painted on the assembly line, the starter is still black where it faces the block.
PostPosted: Fri Feb 07, 2014 9:46 am
Thanks Dr mini does the paint stick to the aluminium? Or does it fall off after a while?
Present
-1979 Leyland Moke
Past
PostPosted: Fri Feb 07, 2014 9:51 am
It sticks best if you etch prime first.
The very best etch primer for alloy was zinc chromate, however it is now banned from sale by the EPA due to being carcinogenic.
But there are many others that work, read the label first.
[edit] Septone super etch primer is OK.
PostPosted: Fri Feb 07, 2014 10:26 am
Thanks Dr mini
Present
-1979 Leyland Moke
Past
Users browsing this forum: Bing [Bot] and 97 guests
