It is currently Fri Jul 18, 2025 6:03 pm
 Post subject: Steering question
PostPosted: Sun Feb 09, 2014 7:23 pm
Ok got a little problem and l think l know the answer but l would like some advice regardless. This afternoon l installed a 7.9inch 4 pot minisport drive assemblies. But now I've got this problem, steering wheel is at dead centre, my wheels are now opposing each other 11 o'clock and 1 o'clock.
Now what l don't understand is why this has happened. Is it because I've gone from solids to vented discs, or because my hubs are now from a 8.4 inch setup or have l done something stupid? Can l wind out the the tie rod to correct this? Then get to a tyre shop for a alignment. Thanks!
1993 R32 Nissan Skyline GTR
 Post subject: Re: Steering question
PostPosted: Sun Feb 09, 2014 8:11 pm
Make sure you don't run out of thread on the Tie rod ends . You might need to use the longer Ball joints.
I think you are going to need arches too.
"Let us remove your "SHORTS"
PostPosted: Sun Feb 09, 2014 9:14 pm
The Mini King
Did The brakes come With steering arms or did You use Your
steering arms, What are the part numbers cast in the steering arms
PostPosted: Sun Feb 09, 2014 10:48 pm
The short answer is that disc and drum brakes use different steering arms.
Easiest thing for you is to swap them over.
PostPosted: Mon Feb 10, 2014 4:13 am
No the brakes didn't come with steering arms. I was running 7.5inch solids with no dramas
PostPosted: Mon Feb 10, 2014 4:15 am
I shall get back to you with a part number, though they are standard oem items (76 clubman)
PostPosted: Mon Feb 10, 2014 9:53 am
The Mini King
I Think You may find that some of the Australian built Minis
with drum brakes also used the same steering arm as the disc brake models
That is why I enquired about the Part Number
PostPosted: Mon Feb 10, 2014 2:07 pm
Put it on the ground and see what happens.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Feb 10, 2014 3:21 pm
John on the end of the tie rod it is stamped bk 37 41 2
PostPosted: Mon Feb 10, 2014 3:22 pm
Yer done that no good!
PostPosted: Mon Feb 10, 2014 3:26 pm
It's the steering arm part numbers he needs to know. There were different lengths for different applications.
PostPosted: Mon Feb 10, 2014 3:43 pm
PostPosted: Mon Feb 10, 2014 3:52 pm
My bad steering arms were supplied my minisport as part of the kit. It is numbered v96a
PostPosted: Mon Feb 10, 2014 3:58 pm
This may help.
PostPosted: Mon Feb 10, 2014 4:17 pm
winabbey wrote:
This may help.
Thanks for that info, l searched that part number l found on the steering arm on mini sports website and nothing came up, though l think they supplied this.
http://www.minisport.com/bta895-steerin ... -s-lh.html
I'm thinking that these might help my problem, john do you sell these?
http://minisport.com.au/prod730.htm
Users browsing this forum: Bing [Bot] and 114 guests
