It is currently Sat Jul 26, 2025 9:30 am
PostPosted: Thu May 12, 2005 11:12 pm
Dylan's Clubby wrote:
A rotisserie is what you can put your mini (roundie only) on!
I just built one for my clubby van and it has no hole to pass the bar through the scuttle panel. All made of wood too.
Chris
Everything I like is either
PostPosted: Thu May 12, 2005 11:16 pm
I think you fll find all Mini's will have a hole in the fire wall :!:
If its van... roundy or clubby you will have to make uo a jig :!:
PostPosted: Thu May 12, 2005 11:18 pm
wish I had one of them now... lol.... its going to hurt trying to to under the 850 in the next few weeks....hmmmm.. where can I get one....
 Post subject: Mattress
PostPosted: Thu May 12, 2005 11:34 pm
Just push it over on its side onto some suitable padding like an old mattress...
PostPosted: Thu May 12, 2005 11:44 pm
The very late cars did not have the hole. Why I don't know. Anyone?
Chris
PostPosted: Fri May 13, 2005 6:46 am
After production moved to Enfield they gave up rotodipping so deleted the holes.. :x
IMO that's why later ones rust faster!
PostPosted: Fri May 13, 2005 5:48 pm
Thats what Im after Doc, but have you got any photos of how it attaches to the rear hole from in inside?
Thanks
Craig
PostPosted: Fri May 13, 2005 7:31 pm
Thanks
Craig
Here's a front mount detail-
Only pic of the rear is the one showed, here it is bigger. There's a curved plate bolted to the holes in the seat back, welded at an angle onto the pipe.
PostPosted: Fri May 13, 2005 9:44 pm
When I was working at JRA I went to Enfield quite a lot. What a two bob operation that was. It was like assembling cars with a giant meccano set.
Chris
PostPosted: Mon May 16, 2005 5:03 pm
Just looking around and I found this site it gives some instructions on making a rotiserie for your mini. I is able to deal with not having the hole in the back seat too :wink:
http://minimikebc.tripod.com/rotiss.html
Roads need more corners
PostPosted: Mon May 16, 2005 6:06 pm
Thanks alot fuzzy-hair man thats a great site, I think i will be using 3" pipe and not 2" as shown on that site , it tends to bend a bit and can be seen in the photos .
thanks again
craig :D :D :D :D
PostPosted: Mon May 16, 2005 7:10 pm
The one I borrowed was 4" pipe I think. I wouldn't make it less.
BTW, make the pipe long enough to leave 300mm clear of the car at each end. Otherwise, it's hard to assemble.
