It is currently Tue Jul 22, 2025 1:21 pm
PostPosted: Wed Feb 12, 2014 10:34 pm
How much would new shock absorbers affect the ride height of a mini? I would have thought very little if at all but I thought I would bounce the question here as others might know something I don't?
Behold! The mighty 850!
PostPosted: Wed Feb 12, 2014 11:33 pm
New cones and shocks make a big differance in ride and height cant feel a bump in the road just about
Dont know about just the shocks but as i changed both at the same time
PostPosted: Thu Feb 13, 2014 12:14 am
No shocks wont affect your ride height.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Feb 13, 2014 7:58 am
If you want to change your ride height, go for hilos. They're a very cheap mod and easy to install. A cone compressor makes things easier, but not necessary. A set of hilos is cheaper than a set of new shocks.
The shocks act as a damper - there is no (or very little) spring tension in them. The rubber cones act as the spring, the shocks act as the damper.
PostPosted: Thu Feb 13, 2014 8:21 am
I thought so. I have the new rubbers and hilos but I'm tired of waiting for them to settle. I don't want to add new shocks if it will slow down the process.
PostPosted: Thu Feb 13, 2014 8:25 am
It shouldn't affect the process at all. It's not just a matter of waiting for the new rubber to settle in just from the weight of the car - you might need to 'flex' it a little - like how stretching a balloon before you blow it up makes it easier. A few work-outs around some nice corners should speed the process up a little.
