It is currently Wed Aug 06, 2025 11:31 am
PostPosted: Sat Feb 15, 2014 8:30 pm
As per the title my moke still had a miss
it has been progressively worse and has moved in permanently
So its a
Std 998
1.25 carb
Std exhaust and air clear
Std cam
I have replaced the following with new parts
Dizzy cap
Rotor fits nice and tight on the spindle
Points dwell reading 50 degrees
Condensor
Dash pot has oil
The leads are with in spec
I have tried the following timing setting
The timing to 5 then 10 then 15 degress. It runs better with 15 plus degrees
Its running way to rich. Checked the needle which is gx std needle for tge 998, and it straight
Leened off the mixture then richend slight improvement if its richend
Compression is 140 even across each cylinder
Firing order is 1342
I am not sure what else to try
Any recommendations would be welcome
Ta kiwiinwgtn
PostPosted: Sat Feb 15, 2014 9:23 pm
Plug gap?
Many new plugs are pre-gapped to 1.1mm, which is way too wide for std ignition. They should be .025" if running points.
PostPosted: Sun Feb 16, 2014 8:09 am
Hi Kev
I did check that and they where not set to 25 thou
I am dreading its a cracked head
Next step I will pull down the dizzy and make sure its advancing correctly
Then the carb.
Ta kiwiinwgtn
PostPosted: Sun Feb 16, 2014 8:34 am
Does it miss under liad or at idle. When the engine is hot or cold?
Could be a bad voltage supply to the coil or the coik is buggered
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Feb 16, 2014 8:23 pm
Boomini wins the mini bingo.
It was the coil in the end.
I did swap out the dizzy which made no difference until I swaped the coil.
I will put in the old one once I strip in down and give it a clean. The neighbours complained that I was making to much noise :shock: first time in 20 years
Thanks for the suggestion boomini
PostPosted: Sun Feb 16, 2014 9:17 pm
Your welcome mate
Minis..
1975 van
PostPosted: Sun Feb 16, 2014 9:26 pm
Make sure you place the old coil in bin.
"Let us remove your "SHORTS"
PostPosted: Sun Feb 16, 2014 10:13 pm
Will do.
Users browsing this forum: Bing [Bot] and 50 guests
