It is currently Thu Aug 21, 2025 5:42 pm
 Post subject: oil pressure question
PostPosted: Mon Feb 17, 2014 8:56 pm
Whats the normal oil pressure psi I should be getting?
Just wondering as it usually sits 3/4 of the way. (70psi ?)
most of the time as soon as I start the car the pressure will rise up to about 60-70psi. sometimes up to 90 I think when cold.
However sometimes when I start it it sits at about 20 psi... Will rise up to 40 after some time and when I then drive off after a while it goes up to 60-70psi. is that a worry? I know theres a bit of air in the lines going to the gauge. just wondering if I should worry about it or let it be. drives fine otherwise. Apart form the usual not really wanting to go when cold lol
PostPosted: Mon Feb 17, 2014 9:09 pm
Pull the oil pressure relief valve and give it a good clean. The air in the gauge line has no effect but random pressure changes are not normal. 75 psi (3/4 mark) is.
Cheers, Ian
PostPosted: Tue Feb 18, 2014 7:14 am
Either the valve is sticking as Ian suggested, or it has been replaced with a 9/16" ball. When cold, the high pressure can force the spring to bend and deflect the ball off the seat, giving a scary drop in pressure.
This can be remedied by using a new (straight) spring and fitting a piece of 5/16" dia x 40mm long steel rod inside it.
These days I recommend using the standard valve & spring, not a ball. Less hassle....
PostPosted: Thu Feb 20, 2014 12:48 pm
Ian, you say 75 psi is normal. When I start my mini it will sit around 75psi until it warms up, at which point it idles around 50psi, and drives around 70-75psi. Should I be concerned with a warm idle pressure of 50?
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Thu Feb 20, 2014 2:20 pm
Warm idle pressure of 50psi is just fine.
Even 20 is OK at idle if the motor has a fair few miles on it.
The oil light fitted to lesser Minis comes on at about 8psi! :shock: It's a bit too late really if that comes on when driving along... :lol:
PostPosted: Thu Feb 20, 2014 5:16 pm
Oil light coming on is to prompt you to look at your pressure gauge :roll:
David L
PostPosted: Thu Feb 20, 2014 6:49 pm
Um.. if you owned an 850 or a Mini Deluxe, the light was all ya got... :cry:
I always thought an oil LEVEL light would have been more useful for most A series owners. After all they do like to drink a bit of oilz.
Back in the 60s BMC reckoned using 1 pint (~600mL) in 400 miles was `normal' for a 1098 during warranty period.
Users browsing this forum: No registered users and 151 guests
