Hi Guys,
Michael emailed me to say that you had been discussing my electric Mini
conversion, so I thought I should drop in and say G'day to you all
I'm in Cardiff, South Wales (UK) , so am about as far as you can get from Oz,
but well a Mini nut is a Mini nut whereever in the world they are, right?
It's nice to see some positive responses about the Mini, I've had quite a few
people over here ask about it, especially at the few car shows I've managed to get
it to. Good to see that people all over the globe are thinking "outside the box", even
if only a little bit.
The performance is ok, I'm limited by the mechanical strength of
the belt system I used to attach the motor to the drivetrain, but
that's set to change, and the electric parts are capable of MUCH more...
I'm about to get a 100 HP AC drive system, not sure if I'll put it into
the pickup, or into my other Mini ( a nice 1992 Cooper injection, leather seats, etc )
The pickup would be easier, as it can carry enough batteries to produce the
high volts the AC drive needs. The controller in the pickup is not
the one that's in my webpages - I swapped that out for one that can
dish out 120 HP, though it is turned way down to avoid breaking things!
But yes, the torque band from the AC drive will be awesome - full torque from
zero RPM right up to 6000 RPM, then it stays at constant 100 HP power
right up to 9000 RPM !! So direct drive is likely to be the easiest
way to do it.
So far, I've done around 3000 miles in the electric Mini, mainly for
short trips around town to go to the store, Mini club, etc.
The longest trips were when I took it into work twice, that's
25 miles each way. Luckily my firm doesn't mind me recharging with
their electricity... 25 miles is about the absolute maximum range with
the old lead-acid batteries I've got.
For more range, the answer will be either Saft Nicads ( big flooded ones ),
or Lithiums. ThunderSky Battery in China do some cheaper lithiums, there
have been a few bulk buys organised here in the UK and in the USA, with
people reporting good results. Still expensive, but they work.
The bright yellow Mini certainly attracts attention, with kids pointing
and people smiling as I zip by, with even more weird looks when they realise it's
totally silent ( why's that Mini still moving when I can't hear it's engine? )
The coolest thing is not having to buy any petrol for it EVER - I just plug it in!
Anyway, if you guys have more questions, fire away!
Regards
Richard Bebbington
electric Mini pickup
http://homepage.ntlworld.com/electric.mini/
