It is currently Sat Jul 19, 2025 12:50 pm
PostPosted: Mon Mar 03, 2014 4:32 pm
hey guys my mate has a 1275 Engine sitting in his workshop been there for 15 years he thinks.
I need to offer him something what is it worth?
ill have to check engine numbers as he is only going off his memory that it is a 1275 also has gearboxs and bits n peices
PostPosted: Mon Mar 03, 2014 5:04 pm
maybe $800?
PostPosted: Mon Mar 03, 2014 5:53 pm
It's a Morris 1100S, you can tell by the front engine plate & mounts.
Yeah in unknown condition, I'd say up to $800.
PostPosted: Mon Mar 03, 2014 6:02 pm
The head also confirms it's not a 1275, the fact it's been sat for 15 years I wouldn't offer more than $400 (I'd be starting at $200 if it weren't a mate!).
PostPosted: Mon Mar 03, 2014 6:51 pm
The engine number should start with 12Y.
The 1100S is a 1275cc, the head just won't have the extra bolts as fitted to the Cooper S.
The head a 12G940.
They are a good base for a hotted up 1275. I think they have a large journal crank as well that can be ground offset for stroking - but are prone to cracking.
I spent $4000 doing one up for my Leyland SS.
$200 if it is seized, $800 if it runs.
PostPosted: Mon Mar 03, 2014 7:23 pm
thanks Guys don't really need a new motor at moment but I guess parts are good to have.
there is few more motors, gearboxs, doors etc in the shipping container but he is to lazy to pull the out at the moment.
Might go past on the weekend and clean it out for him.
his dad who use to own the workshop had a few mini copper s back in the day so how knows whats in there.
PostPosted: Mon Mar 03, 2014 8:18 pm
If you can take a few photos and post them on here I am sure will be able to work out if there is anything worth buying.
PostPosted: Tue Mar 04, 2014 7:02 pm
As a guide I purchased a similar motor from Ebay with only block, crank, rods and camshaft for $430 just before Christmas.
I'd value the engine you have around $500 if you want the gearbox and head.
There is always a risk the motor will need a fair bit of machining so don't spend too much.
On the other side 1275s are getting harder and harder to get.
Regards,
HRS
PostPosted: Thu Mar 06, 2014 6:22 pm
I Picked it up today swapped him with some parts he needed
Engine 12YDTA
Gearbox W 22A1522
SM MOWOG
PostPosted: Thu Mar 06, 2014 6:33 pm
more pics coming soon
PostPosted: Thu Mar 06, 2014 8:21 pm
What head does it have? 12G940
PostPosted: Thu Mar 06, 2014 8:27 pm
No idea is there numbers on that two ?
PostPosted: Thu Mar 06, 2014 9:06 pm
It's a 12G940, I can tell from 1st pic.
[edit] That plate on the motor means it was rebuilt by Repco. Back when they actually did work besides selling parts.
PostPosted: Fri Mar 07, 2014 7:31 pm
I wouldn't be offering $800. I would be starting around $300. Then move upwards.
But I'm a Pov and generally don't buy things unless I know im getting a good deal.
PostPosted: Fri Mar 07, 2014 7:36 pm
I swaped him with some parts i have its in good condtion.
Bore is very clean
Oil in it clean
Would make a good engine for someone.
Users browsing this forum: No registered users and 69 guests
