It is currently Tue Jun 24, 2025 10:25 pm
 Post subject: Re: Accelerator cable
PostPosted: Wed Mar 05, 2014 8:10 pm
Mick wrote:
Slide right off.
My ends appear crimped on.... I think I'll just buy a new competed mini cable.
PostPosted: Sat Mar 08, 2014 4:45 pm
Hanra
If you haven't ordered a new cable yet, I found that you need the cable adjuster from the bicycle shop for the inner cable to slide smoothly. It looks like a hollowed-out bolt with a slice down one side, and you need to hone out the cable holder on the engine for the adjuster to sit in snug. I used the brake cable on my clubman and haven't had a problem with it catching. Best of luck.
Mark.
PostPosted: Mon Mar 10, 2014 7:54 am
This is the bracket Ive got fitted to my inlet manifold, Ive run a drill bit through it to open it up a tad but no real difference.
http://www.minispares.com/product/Class ... 0to%20shop
Im not quite sure the bit your talking about?
PostPosted: Mon Mar 10, 2014 8:50 pm
Hanra,
I tried to get a photo, but I've got the mrs yakking on about mkr (annoying) - makes it hard to concentrate. Anyway, go to the local cycle shop, and ask for a brake cable adjuster. Think of it as an allen key bolt that has been hollowed out. It will then be able to sit through the hole in your bracket. You will see it near the brakes on a normal bicycle. If you have any problems give me a ring on 0408704215 any time outside of 12:00 - 12:30 - I'm on Qld time.
Mark.
PostPosted: Tue Apr 01, 2014 7:56 am
Purchased a brand new inner/outer throttle cable from Minispares, fitted the old return springs and it the pedal now feels nice and smooth. Perfect.
PostPosted: Tue Apr 01, 2014 8:14 am
All ready for the MG Car Club run up the hill on Sunday then. Leaving from Skyrail at 10.00am, we will join at Mareeba for run thru to Julatten for lunch. Be good to get the Black S out of the shed . .
Steve
PostPosted: Tue Apr 01, 2014 10:24 am
Ha! I knew nothing of it! Still a little way off from being on the road as yet........ Maybe I take my black car to Skyrail for a drive if its fine.
