It is currently Tue Jul 29, 2025 4:03 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: which PLUGS?
PostPosted: Fri Mar 07, 2014 2:35 pm
I run iridiums in one of my minis that gets used once a year. No problems.
PostPosted: Sat Mar 08, 2014 10:56 pm
I run NGK BP6ES plugs in my mini (mild 998) all year round down here in cold old tassie!
Never had a problem and the plugs really need to be changed as they've been in there for a good 15,000kms. :oops:
I highly recommend them.
My mate was having trouble fouling plugs in his 73 Mazda 929 so we whacked a set of NGK BP6ES plugs in and 5000kms later still going strong.
Cheers, Rhys
1977 Leyland Mini Van - Sold
PostPosted: Sat Mar 08, 2014 11:06 pm
BP6ES and BP5ES plugs also go in some honda mowers i got one last week
PostPosted: Mon Mar 10, 2014 3:17 pm
Is there any advantage in using BP5EY PLUGS (which have the extended electrode nose) over the standard BP5ES?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Mar 10, 2014 3:37 pm
I ran them in the 1412 stroker until we sold it (but they were the resistor version, BPR5EY). Ran just fine, I think BPR5EY are stock AUII falcon plugs so are easy to find.
If you have good plug leads & coil, resistor plugs can give a fatter spark and are less likely to foul.
