It is currently Fri Jul 18, 2025 10:13 am
 Post subject: Hydrolastic Pump parts
PostPosted: Sun Mar 09, 2014 1:22 pm
Hi don't know if this is the right section for this
I recently purchased a hydrolastic pump it works but leaks a bit from the pump seals and the vacuum side is missing the fitting off the end and gauge isn't working
can parts be sourced for these? as I'd like to restore it/tidy it up
any help would be great even what colour it should be
thanks
PostPosted: Sun Mar 09, 2014 5:20 pm
Where do you find this stuff mitch?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Mar 09, 2014 5:57 pm
Bought that from a guy off gumtree recently im guessing, I rang him he told me people were calling from all over the country offering more than what he was asking
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sun Mar 09, 2014 6:53 pm
the guage can be repaired usually, the 'end' you refer to I asume is the hose end?, just an old tyre valve chuck. Our 'original' one was sort of light green hammer tone.
PostPosted: Sun Mar 09, 2014 7:20 pm
Yes it's the one that was on Gumtree
Thanks Peter what about the seals in the actual pump(like the ram) can you get them?
PostPosted: Sun Mar 09, 2014 7:25 pm
I've never actually had one apart but if BMC is associated with it, it won't be too tricky, more than likely rusty in bore/ram. Rip it apart and have a look, probably o rings or similar.
PostPosted: Sun Mar 09, 2014 7:51 pm
morris 1100 is the expert on these pumps... :wink:
PostPosted: Sun Mar 09, 2014 8:18 pm
Mine is black
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 10, 2014 10:46 am
First, the good news. :D Below is a BMC Technical Bulletin that might help you understand how the pump works.
Now, the bad news. :( The repair kits are no longer available.
But some more good news. :D As stated, Morris 1100 on here has refurbished these so could help you locate the component parts.
Also, I can give you the name of someone else who has overhauled several so may also be of help. Just PM me.
PostPosted: Wed Oct 29, 2014 5:09 pm
Getting to the finishing stages of the rebuild of this pump. I got some seals made up for the pressure side(the left side)they couldn't make them to the original ones, they used poly bush however it still leaks a bit
So my question is has anyone got some make up that work? If so where from any help would be great
Thanks Mitch
PostPosted: Wed Oct 29, 2014 7:05 pm
PM 850man and Morris 1100 on here as they have both refurbished these pumps. 850man also sells repro instruction plates that screw to the top.
PostPosted: Wed Oct 29, 2014 7:18 pm
Mitch its no good mate, has a fly on it so must be buggered. As im such a nice bloke I'll take it off your hands and save you the hassles. Im good like that.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Wed Oct 29, 2014 9:29 pm
I have a new plate to go on the top pretty sure I got it from him
Jason it has been a lot messing around for this thing trying to get lines and fittings I'll be happy once its done!
