It is currently Tue Jul 29, 2025 6:14 pm
PostPosted: Tue Mar 11, 2014 7:26 pm
Hi just wondering what the thread size is for the drain tube?
Jarrad
PostPosted: Tue Mar 11, 2014 7:57 pm
Pretty sure it's 3/8 UNF.
PostPosted: Wed Mar 12, 2014 8:09 pm
Cheers Doc
PostPosted: Wed Mar 12, 2014 8:58 pm
Mini King has NOS drain tubes if you need to replace it.
But next time mine comes out I'm sticking a grubscrew in it, IMO the drain tube is a PITA...
The RH tank is easier to remove than the LH one is. :evil:
PostPosted: Thu Mar 13, 2014 12:25 pm
That grub screw idea is a good one , I'll try and find one this weekend , thanks Doc
PostPosted: Thu Mar 13, 2014 12:30 pm
If you put a grub screw in there you'd want some sortof sealant on there too so it can't leak.
PostPosted: Thu Mar 13, 2014 4:17 pm
What sealant would you suggest ?
