It is currently Thu Aug 14, 2025 12:05 am
 Post subject: flywheel to crank
PostPosted: Sat Mar 22, 2014 10:41 am
Hey guys how do you all fut your flywheels onto crank tapers?
Dry or lubricated?
Cheers guys
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
 Post subject: Re: flywheel to crank
PostPosted: Sat Mar 22, 2014 11:07 am
"Do not under any circumstances use grease, oil or any lubricating product on the taper of either part.
You may however use Loctite 222# to act as a lubricant to assist the flywheel moving up the crankshaft taper. If using Loctite leave for 15 minutes before removing the nut and apply some 222# to nut and thread and retighten as before."
Don't quote me Rodney I found this on another 'how to, forum!
Sounds like you have a big day ahead of you!
PostPosted: Sat Mar 22, 2014 11:12 am
Also found this:
http://www.minimania.com/msgThread/111398/1/1/Flywheel_problems
The forth comment suggest dry fitting!
I'm the only one up this morning, not allowed to make noise and I'm bored!
PostPosted: Sat Mar 22, 2014 11:24 am
Haha.. s I when it falls in a heap im blaming you marty.....
I figured it was a dry fit but just thought I would ask.
Minis..
1975 van
PostPosted: Sat Mar 22, 2014 11:31 am
My better half has always claimed I only have two faults;
Everything I say & everything I do!
So I wouldn't be taking my word for it Ha ha....
PostPosted: Sat Mar 22, 2014 11:33 am
Lol
Minis..
1975 van
PostPosted: Sat Mar 22, 2014 5:28 pm
When I rebuilt my motor last year, I put some STP on the crank taper and then put the flywheel on.... the motor was still on the bench in January, and I wanted to take the flywheel off again in January.
it ... would ... not ... budge
my puller is 3/4" thick, and it had about 2mm of bend across the face of it from the amount of tension that was on it. I bashed, heated, bashed, heated, left it for a week, then gave up and left it on there
use a bit of fine valve lapping paste and lap them to each other, then make them really clean and put them together dry
Users browsing this forum: No registered users and 324 guests
