It is currently Wed Jul 30, 2025 12:10 am
PostPosted: Tue Mar 25, 2014 10:35 am
There's a boot that goes over the top of the remote gear shift and under the main rubber gaiter which stops crap flying up out the the bottom of the lever. I'm trying to find a name or part number so i can order one for Karcraft as mine is kaput. Ideas?
PostPosted: Tue Mar 25, 2014 10:51 am
GSV1073.
see p118 of Mini King book. Item 1.
I would use this diagram.
From this diagram https://www.somerfordmini.co.uk/eshop/i ... age&id=151 ??
PostPosted: Tue Mar 25, 2014 11:02 am
I don't think remote change one's had 2 boots but 22a1380 off 850 might work. GSV1073 is an axle boot ????
PostPosted: Tue Mar 25, 2014 11:06 am
Correct the GSV1073 is an exle boot. But I'll check the 22a1380.
PostPosted: Tue Mar 25, 2014 11:12 am
22a1380 would possibly fit early remotes? Does yours have tin cover round shifter? 53 in picture
PostPosted: Tue Mar 25, 2014 12:02 pm
There's no tin cover from memory. Hence the extra boot to stop crap coming up.
PostPosted: Tue Mar 25, 2014 12:08 pm
The Mini King
Cooper_Matrikon wrote:
Correct the GSV1073 is an exle boot. But I'll check the 22a1380.[/quote
You Are Correct It is a pot joint boot And It Fits Perfectly on the bottom
of the gear leaver
PostPosted: Tue Mar 25, 2014 12:09 pm
Awesome!
PostPosted: Tue Mar 25, 2014 3:49 pm
The Mini King
The Boot He wants is not in this diagram, But it is in The Mini kingdom Book
