It is currently Fri Jul 18, 2025 12:15 pm
PostPosted: Wed Mar 26, 2014 9:58 am
had a tiny bubble on the bottom of my door but knew the horrors that would be on the inside and i was right
PostPosted: Wed Mar 26, 2014 7:32 pm
Look on the bright side, at least you can get new door skins.............
PostPosted: Wed Mar 26, 2014 10:56 pm
Should be here tomorrow :)
PostPosted: Thu Mar 27, 2014 3:38 pm
wish we could get new skins for aussie doors :cry:
PostPosted: Sat Mar 29, 2014 6:02 am
Why can't you?
PostPosted: Sat Mar 29, 2014 11:24 am
No one makes them, only English ones available :cry:
PostPosted: Sun Mar 30, 2014 9:47 am
didnt know they were different :roll:
got my alloy ones fitted
one door rust free
got my parts from minispares so will be flat out over the next few weeks
PostPosted: Wed Apr 02, 2014 8:45 am
fixed the scuttle today as didnt have much time with it today
before
after
well i never took a picture of the last door frame it was much worse then this and a pain in the bollox to fix
sorted
PostPosted: Wed Apr 16, 2014 12:17 pm
well have both doors skinned now and blocked out!!! mad to think there is this many low spots in a new skin (wtf:
bonnet hinges sorted
front arb done
PostPosted: Wed Apr 16, 2014 6:04 pm
Is that ARB bracket welded straight onto the lower control arm? :? could there be an issue with strength/snapping the control arm...
PostPosted: Wed Apr 16, 2014 7:29 pm
:shock:
I like low cost builds but that's a real no-no. Better to clamp a bracket to the arm than risk it failing due to the heat affected weld are.
M
PostPosted: Thu Apr 17, 2014 11:23 am
It’s more than that front lower arm that worry me.
I’m not normally one to pick on people builds because quite often the stuff we see here is just mock up stuff, not the finished product, but if I see something I think could be a safety concern I feel it should be noted, not only for the owner of the car to make their own decision on fixing it but to stop any ‘copy-cat’ behaviour from backyarder people building the same who don’t see the finished product.
I’ll skip over the subframe design and the materials used in it and the construction method, I’ll just say there’s room for improvement.
Brakes: the linkage running across the dash from the pedal to the booster is not secured to the car chassis in any suitable way at all. We can see one 5/16 nut holding the drivers end down and the shaft retained with another at the other end. If somone hits the anchors hard enough the drivers side one will strip and then its no more brakes. If the one at the other end wears and breaks, same result. I’m sure this isn’t going to be the finished product, but just pointing this out incase.
Alternator bracket: the tags holding the alternator up are very thin. Watch for cracking.
Rear subframe: the cut down rear frame is still rubber mounted. It has no torsional rigidity left without closing the open ‘c’ section up and ditching the rubber mounts.
The vertical control arms that have been shown shortened have clearly been done without doing a full penetration butt-weld. What’s there is at higher risk of cracking.
The gold JS racing thing: if it’s a stabiliser it’ll rip clean out of the firewall, and you can see this has happened before.
Driveshafts: the short shaft has a very small diameter section in the middle. Could probably do with another layer of weld around there unless it’s intended to be a shear point.
PostPosted: Sat Apr 19, 2014 11:00 am
i get what you are saying with the front arb bracket but i welded it in stages not to put too much heat though it at once.
the brake bracket is welded in and 2 nylon bushes in each end so the weight is on the bar not the treaded bold so unless you snap the bar you wont lose brakes
the rear subframe isnt rubber mounted its fixed by 10 m12 bolts with solid spacers the orgininal mounts were left in place to make it easy to mount straight
the drop links are just for mock up will be replaced with rose joined drop links
shafts they were made by a shaft specialist so i trust them
PostPosted: Sat Apr 19, 2014 11:53 am
That makes me feel better then - still not sure about the lower control arms. Are they cast or forged?
PostPosted: Sun Apr 20, 2014 12:30 am
I thought they were forged, but I could be wrong.
