It is currently Wed Jul 16, 2025 2:59 pm
PostPosted: Wed Mar 26, 2014 4:50 pm
Hi all
I currently have my 998cc 1968 Morris Mini Deluxe in rehab having a full overhaul. She is currently registered with an 1100cc clubby motor with 'S' discs but as of recently has had a transplant with a Metro A+ 1275cc engine.
I was wondering how the NSW RTA feels about this. Will I definitely need a engineering certificate or can I get through with a change of details?
I am trying to avoid getting it engineered because the main driver is a Provisional driver and cannot drive cars with an engineering certificate.
If someone could shed some light it would be greatly appreciated!
Thanks
James
PostPosted: Wed Mar 26, 2014 5:03 pm
No engineering needed. Just a blue slip for the engine swap.
Its a factory engine - as long as the car has disc brakes you'll be fine.
PostPosted: Wed Mar 26, 2014 5:17 pm
Well that put my mind at ease, I was worried about the certain % larger engine capacity needing a signatory.
Thanks!
PostPosted: Wed Mar 26, 2014 5:40 pm
Nah - A series is no problem. How else do you think people get their 1.6 and 1.8 converted cars registered?
PostPosted: Thu Mar 27, 2014 5:57 pm
The only trouble I ever had with engine changes in NSW was when fitting a 1098 Clubby motor (~1974) into a 1978 Clubby.
The dill doing the blueslip objected that the motor was `older than the car- you can't do that' he said.
I said `the two blocks are identical, so we are just arguing about the numbers stamped on it?'
`Yes' he said.
I said `fine' and went elsewhere. :roll:
I wonder how engine reconditioners got on then.. there was no guarantee their recond exchange engine was `newer' than your old one.
PostPosted: Thu Mar 27, 2014 8:40 pm
I've registered a '71 1100 engine in an 88 model - didn't even have a cat or pollution gear! :lol:
Funny how some are sticklers for the laws and other arent.
You want to find the oldest inspector you can - younger people are more likely to be doing their job by the book.
PostPosted: Sat Mar 29, 2014 10:36 am
nah, thats just because you're in Victoria
