It is currently Thu Jun 26, 2025 9:28 pm
 Post subject: electrical gremlin
PostPosted: Mon Mar 31, 2014 8:53 pm
High heel ninja
I have a electrical issue with my clubman, when its running, the tacho reads normally, when I turn the headlights on, the revs on the tacho dip to half, say its doing a 1000 rpm, it dips to 500, and the right blinker comes on, but doesn't flash, I thought it maybe a earth issue, I clean up all the earths, but nothing change.
Any advice would be great.
Doogie
 Post subject: Re: electrical gremlin
PostPosted: Mon Mar 31, 2014 9:01 pm
My guess us an issue in the dash or maybe voltage regulator
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Mar 31, 2014 9:21 pm
Are we talking a 3 clock dash or an aftermarket tacho?
If std 3 clock dash is it a current or voltage sense tacho?
Cheers Shane
PostPosted: Tue Apr 01, 2014 6:55 am
My guess would be the earth side of your car electrical system. Check your earth for lights as it seems that when lights are turned on is when the problem occurs.
"Let us remove your "SHORTS"
PostPosted: Tue Apr 01, 2014 9:52 pm
Tomboss Breweros
Make sure everything to do with the right headlight and blinker is ok at the globe, electrical problems can back track in weird ways.
kimini wrote:
Jimmyinamini wrote:
