It is currently Mon Jun 30, 2025 5:24 pm
PostPosted: Fri Apr 04, 2014 4:01 am
Before taking the plunge...are there any particular fitment issues installing an LCB and RC40 with 'Puddin Stirrer' transmission with rubber/steel inner joints?
I ask because there was a bit of fiddling required to ensure clearance between stock exhaust and QH joints (since replaced with standard).
PostPosted: Fri Apr 04, 2014 6:56 am
Hi Rick,
I believe there is a problem with room when fitting a Maniflow LCB and rubber cross U/Js, rumour has it a pipe needs denting in for clearance.
I know it's more work but I would be fitting pot joints & shafts instead... as the rubber ones are not durable these days.
Alternative (but costly) is fit Hardy Spicers, they will slide onto the splines of your existing driveshafts.
[edit] If you want to keep rubber U/Js I would fit a Maniflow freeflow header instead.
Last edited by drmini in aust on Fri Apr 04, 2014 7:41 am, edited 1 time in total.
PostPosted: Fri Apr 04, 2014 7:28 am
Maniflow/minispares/minimania stock two different versions - one is shaped slightly different to fit around the rubber joints. They're double the price though!
Normal
http://www.maniflow.co.uk/index.php?vie ... oduct=1319
Alternate
http://www.maniflow.co.uk/index.php?vie ... oduct=1122
The Freeflow Cooper style manifolds fit on fine with the rubber joints
http://www.maniflow.co.uk/index.php?vie ... oduct=1507
PostPosted: Fri Apr 04, 2014 8:14 am
Thanks for the quick responses...I have new pot joints and related drive shafts so that is the way I'll go!
