It is currently Mon Jul 21, 2025 11:58 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Apr 05, 2014 12:52 pm
Babes wrote:
Ill come and watch the strip down, hide some parts etc im good like that
Yep I'll come to and drink your beer Marty.. Oh and learn [GRINNING FACE WITH SMILING EYES]
66mini van,77 clubby,78 LS1275,60sRoundy.
PostPosted: Sat Apr 05, 2014 12:57 pm
How can you go wrong with a crack team like this 8)
PostPosted: Sat Apr 05, 2014 1:27 pm
If all else fails we drink beer and complaint "what idiot designed this thing anyway!" :D
PostPosted: Sat Apr 05, 2014 2:24 pm
This might help - viewtopic.php?f=25&t=85150
PostPosted: Sat Apr 05, 2014 3:13 pm
These vids from Mini Mania might help too
http://www.youtube.com/watch?v=tsOJPemcEDc
PostPosted: Sat Apr 05, 2014 4:22 pm
Yes beer makes everything better
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sat Apr 05, 2014 5:18 pm
Cheers guys, seen the video's they will certainly be handy on reassembly I only hope I get my case looking as clean 8)
Is it worth replacing all bolts?
PostPosted: Sat Apr 05, 2014 5:50 pm
Come grab the books when you want mate
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Apr 08, 2014 9:42 pm
Finally got the gears to lock after replacing the lay gear! Now the nut is too bloody tight!! Soaking overnight in WD-40 and I'll try again tomorrow. Failing that I'll take it to workshop and get help :D
PostPosted: Wed Apr 09, 2014 6:37 pm
http://www.minimania.com/Gearbox_Rebuild
http://www.minimania.com/Classic_Mini_G ... ania_Video
You'll need these when putting it back together
David L
PostPosted: Wed Apr 09, 2014 7:55 pm
soaking in WD40 won`t help,,, it lives in oil normally :-)
PostPosted: Wed Apr 09, 2014 10:04 pm
Previously I've used a breaker bar (1/2" drive) and about 5 feet of exhaust pipe. This is the sort of force you may have to apply, you also have to be able to pin the box with the same amount of force, such as bolting it to an immovable object.
You may also have to apply heat, be weary though you can start to anneal steel over time with temperatures as low as 300 degrees.
PostPosted: Thu Apr 10, 2014 12:04 am
Cheers Wombat, and thank you to everyone else that chipped in. Finally got if apart! (Told you I'm slow!)
Next question: what's the best way to clean it up? Chemically?
Should I remove the bolts and clean the thread or leave them as is?
Cheers :D
PostPosted: Thu Apr 10, 2014 5:47 am
I just did exactly the same job last weekend. Went through similar struggles too. I even had a copy of the pages of the Haines manual laminated so I could wipe the sludge off.
I have dropped all the casings and transfer housing and wok cover to a guy to soda blast. He's quoted $100 to do the lot, due back early next week - if your interested I could post some before and after photo's if you like?
Oops what am i doing here?
PostPosted: Thu Apr 10, 2014 9:19 am
Yes please photos would be great :D
