It is currently Thu Jul 17, 2025 7:32 pm
 Post subject: What should I look for?
PostPosted: Sat Apr 05, 2014 5:45 pm
Hi all,
I am having a look at a 77 clubman van tomorrow, just wondering what I should be looking for, I don't think it has been started in a while. I am not too worried about engine but am more worried about body eg common rust spots.
Thanks in advance
Matt
PostPosted: Sat Apr 05, 2014 6:05 pm
Rust in the bottom of the rear doors (check under the rubbers), rust around the lower rear corners behind the wheels mainly from the seam upwards about 2", and possiably behind the seats under the loadbay where the rear subframe meets the body but that's the same with a sedan, then you have the normal areas any mini rusts like sills, front floor pans, hinge "A" panels, windscreen scuttle panel etc etc.
PostPosted: Sat Apr 05, 2014 6:13 pm
Cracks at the top and bottom of the rear door pillars.
PostPosted: Sat Apr 05, 2014 6:21 pm
Hi KR4MPT, what's your location?
PostPosted: Sat Apr 05, 2014 6:23 pm
Ballan vic
PostPosted: Sun Apr 06, 2014 12:37 am
cool, more mexicans
It's easy once you know how.
