It is currently Sat Jul 19, 2025 3:32 pm
 Post subject: Engine movement
PostPosted: Tue Apr 08, 2014 8:42 pm
G'day fellas how are ya all??? Have a quick question, I know with the old school minis Your to have zero movement with the motor when you accelerate or decelerate. My question is my dad has a Rover mini and if he starts it and let's his clutch off and on a little bit the engine moves a little bit, is this normal or is something broken? Or worn? The rubbers are new in the engine stabiliser. Cheers fellas
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: Engine movement
PostPosted: Tue Apr 08, 2014 8:48 pm
Has it got the stabilisers under motor?
PostPosted: Tue Apr 08, 2014 8:51 pm
Gotta check the rear mount rubber behind the remote as well. When there has been rocking, it comes down the remaining undamaged rubbers to absorb the shock. Sometimes they go out in sympathy.
A remote gearchange engine should be as solid as a rock. Rocking issues in road goers are for rod change in my opinion!
PostPosted: Tue Apr 08, 2014 9:14 pm
Yes has stabilisers under motor
1970 mini k
1975 leyland
PostPosted: Tue Apr 08, 2014 9:32 pm
Maybe try looking while someone CAREFULLY takes up load on and off. see what's loose.
PostPosted: Tue Apr 08, 2014 9:39 pm
front subframe is rubber mounted on the later rovers,,,
probly worth a look to see if they`re broken (probly are)
you only need to stand there turning the steering wheel left-to-right & watch the whole engine & frame move side-to-side :-)
PostPosted: Tue Apr 08, 2014 9:42 pm
I did that Peter and it looks like there's movement where the stabiliser bolts to the motor although if tried getting a spanner down there ( with difficulty ause everything's in the way) and it seemed fairly tight.....
1970 mini k
1975 leyland
PostPosted: Tue Apr 08, 2014 9:49 pm
Oh, Rover. Apologies.
PostPosted: Tue Apr 08, 2014 10:27 pm
The rubber mounts in the lower stabilisers don't seem to last, there's a lot of leverage on them. I fitted these and they seem to be lasting ok.
http://www.minispares.com/product/Class ... stabiliser bush.aspx|Back to search
PostPosted: Wed Apr 09, 2014 8:30 am
With the engine stabiliser is it the same as say my mini k? With a bracket then the stabiliser then another bracket? If that makes sense... So a bracket right up against the block then a stabiliser then another bracket.
1970 mini k
1975 leyland
