It is currently Wed Jul 23, 2025 8:27 am
 Post subject: Damaged Gears!
PostPosted: Thu Apr 10, 2014 1:47 am
After finally pulling my gearbox apart I have removed most of the gears and bearings from the motion shaft. On inspection most of the cogs look good, no damage, no pitting except two!
The first one I think is part of third gear! One tooth has snapped! Plus I can't get the pegs or plunger things in to remove the thrust washer! Any suggestions?
Secondly the Final drive pinion has three teeth in a row damaged! Where's the best place to find replacements of these two parts?
P.S. They are clean, it's the light that make them look rusty!!
P.P.S. The baulk rings all look fine, should I replace them as a matter of course?
 Post subject: Re: Damaged Gears!
PostPosted: Thu Apr 10, 2014 7:33 am
To be honest , if the rest of that 3rd gear is like all the other teeth, & only that one dog has chipped off
then i`d re-use it, shouldn`t be an issue at all
the pinion doesn`t look too bad either really, but i can`t really see the whole thing so it`s a bit hard to tell,,, ive seen way way way worse in a mini & still going ok
PostPosted: Thu Apr 10, 2014 7:40 am
Pinion damage is often caused by people when using a cold chisel to flatten the locktab. You need to be careful to keep pressure off the teeth, they are brittle.
I's use the 3rd gear but find another pinion, and a crownwheel too if it's marked.
PostPosted: Thu Apr 10, 2014 8:44 am
The Mini King
With Regards to the pinion, The crown wheel is not as wide as the pinion
You should be able to see where the two have meshed, if the damage is
outside of this area, then I would suggest You can use it without problems.
In my opinion when ever a gearbox is rebuilt care should be taken to mesh
the crown wheel and the pinion back the way they have been running before,
Some people may disagree with this,
the other thing I noticed is the amount of teeth on the pinion
I cannot remember if You mentioned what car this is going in
PostPosted: Thu Apr 10, 2014 10:02 am
Cheers guys great advice :D
PostPosted: Thu Apr 10, 2014 10:11 am
Looks like I'll need to find a new pinion I suspect you are correct, I think it could have been my Neanderthalic removal that caused the damage! The crown wheel is fine.
PostPosted: Thu Apr 10, 2014 10:14 am
The pinion has 15 teeth and the gearbox is going onto a 1275 that I'm attempting to rebuild! That will be fitted to my 78' Leyland.
PostPosted: Thu Apr 10, 2014 10:56 am
If it's only 15T, the diff ratio is either 4.13 or 4.26.
Way too short gearing for a 1275 in a road Mini, IMO.
I'd look for a 3.44 (18T/62T)
PostPosted: Thu Apr 10, 2014 11:20 am
Thank you :D
PostPosted: Thu Apr 10, 2014 11:26 am
Just about every rodchange box (except Moke) had a 3.44 diff in it.
Fit pot joints whilst you're about it.
PostPosted: Thu Apr 10, 2014 6:20 pm
The Mini King
This is why I mentioned the Pinion to You, with 10inch wheels
it will get of the mark quick, but will run out of legs pretty quick as well
There is one more ratio with a 15 tooth pinion that I can recall 4.33:1
so they are 15/62 15/64 15/65
4.13 4.26 4.33
PostPosted: Thu Apr 10, 2014 8:39 pm
It's 15/64 (4.26) and I'm running 12 inch wheels.
PostPosted: Thu Apr 10, 2014 8:59 pm
At 113kph you will be doing 5000rpm.
It is a silly diff for any road Mini.
PostPosted: Thu Apr 10, 2014 9:03 pm
What would people recommend?
Mostly daily driver with occasional highway runs
PostPosted: Thu Apr 10, 2014 9:06 pm
3.44 will be the best compromise for a daily
Users browsing this forum: drmini in aust and 82 guests
