It is currently Tue Jul 29, 2025 7:25 am
 Post subject: Suspension setup
PostPosted: Mon Apr 14, 2014 7:07 pm
Hey I've got to get my geometry all re-done, on my car and I'm after advice on other members setups
I'm planning on taking my car to Jim hunter suspension up at blacktown unless you guys can recommend somewhere better. I'm after a fast road/ odd track day setup......
1993 R32 Nissan Skyline GTR
 Post subject: Re: Suspension setup
PostPosted: Wed Apr 16, 2014 1:37 pm
1/16th" toe out at the front
1/16th" toe in at the rear
camber depends on your tyres & your driving but generally for road use with your average road tyres (falkens etc)->
.5deg neg camber on all 4 corners
& 3 to 4 deg caster on the front is pretty sweet
if you`re racing it on yokos then they like more camber (Maybe 1.5-2deg neg)
But if you`re using Hoosier-daddys then they like being straight up-n-down = no camber
PostPosted: Wed Apr 16, 2014 4:41 pm
Thanks mate for the reply
PostPosted: Wed Apr 16, 2014 5:16 pm
I an running 1/16th tow F&R as the Doc has suggested, I am running +6 degree caster, its heavy but helps heaps with the torque steer from the turbo whack, camber on the front is 2 degrees and camber rear is.5 degree.
drives very nice
100% Pure A Series Turbo
