It is currently Tue Jul 29, 2025 12:46 am
 Post subject: rear bump stops ?
PostPosted: Wed Apr 16, 2014 9:18 am
Currently rebuilding a dry rear sub frame, should I re-route the flexible brake line from the top of the arm to the underside so I can run bump stops?
 Post subject: Re: rear bump stops ?
PostPosted: Wed Apr 16, 2014 1:20 pm
If you want to run bumpstops, you will need to. Put a hoseclamp round the arm to hold the pipe in position.
Instructions are in the comp bumpstop kit. Kc carries the bumpstop kit in stock.
PostPosted: Wed Apr 16, 2014 3:55 pm
Thanks Kev
What would you run up front in the way of a bump stop?
PostPosted: Wed Apr 16, 2014 4:06 pm
junior wrote:
Thanks Kev
Standard conical ones. Either dry, or hydro.
Do NOT run the comp hydro front ones unless you are going rallying.. they are way too tall. As I found out...
Users browsing this forum: Bing [Bot] and 95 guests
