It is currently Fri Jul 25, 2025 1:44 am
 Post subject: Con Rod 12G1507
PostPosted: Fri Apr 18, 2014 6:28 am
What are 12G1507/8 con rods out of?
I have a reference for a 1275GT but can't confirm that - Aussie or Pommy?
Are they a good quality factory con rod?
 Post subject: Re: Con Rod 12G1507
PostPosted: Fri Apr 18, 2014 7:44 am
I think you will find they are numbered 12G1506/8 in parts books.
[There is a discrepancy of 1 digit between cast or forging numbers, and part numbers.
For example, C-AEA648 and 649 are the same race camshaft].
Big journal A series `lumpy cap' rods, used here in late GT, Morris 1100S, 1275 Moke, and 1275LS.
They were the rod used here, and also UK before the lighter A+ ones came in ~1980.
I confirmed by looking at pics on the web-
http://www.theminiforum.co.uk/forums/to ... 0-pistons/
They work OK for most use, but IMO the caps need lightening, I'd mill 8mm off the lumps and rebalance them. Fit new ARP bolts.
You want better [aftermarket] rods for a race motor, IMO.
PostPosted: Fri Apr 18, 2014 10:50 am
Thanks for the info, definitely have 12G1507/8 cast on the rod.
