It is currently Mon Jul 21, 2025 7:05 pm
 Post subject: Silly hs4 question
PostPosted: Fri Apr 18, 2014 10:31 pm
Evening All,
Silly question for you all...
Which side is the float bowl on a hs4 normally for a Mini?
I have two with the bowl on the clutch side.
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
 Post subject: Re: Silly hs4 question
PostPosted: Fri Apr 18, 2014 10:52 pm
The opposite side to a HS2.
PostPosted: Fri Apr 18, 2014 10:53 pm
That is normal, for a single HS4.
There is also a rarer opposite hand one, but that is used only as the LH carb in twin carby sets (3 bearing MGB, and Mk2 Cooper S with Police pack).
PostPosted: Sat Apr 19, 2014 4:20 pm
Well there you go then.
Thanks Gents
