It is currently Tue Jul 01, 2025 3:32 am
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
PostPosted: Fri Mar 21, 2014 12:44 pm
I have some near new inlet valves here that had Minisport rollers on them, all 4 had a concave radius on the end of the valve stem before I ground them flat.
I'll stick to non-rollers, thanks. :wink:
PostPosted: Sun Apr 20, 2014 11:14 am
Has anyone tryed the MED roller rockers? They look pretty good. The price seems good as well.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Apr 20, 2014 7:35 pm
Chux wrote:
......they mushroom the top of the valves instead! ;-)
I'd be pretty interested to know how this could happen :(
PostPosted: Sun Apr 20, 2014 7:55 pm
No idea, all fixed now though and hasn't happened since. Might just have been a suspect valve?
PostPosted: Sun Apr 20, 2014 8:18 pm
Some valve stems are stellite tipped (=hard) but most are soft.
The contact radius of roller tip rockers is a lot less than that of normal rockers. So, the valve spring load is concentrated in a smaller contact area when the rocker opens the valve. Potential for faster wear/valve stem damage.
PostPosted: Tue Apr 22, 2014 3:49 pm
Yep, I had this happen to three of eight new valves a couple of years back. The rockers weren't at fault, it was the valves. Lower end Minispares ones, I guess 5/8ths of the time you get what you pay for with low end valves...
PostPosted: Wed May 07, 2014 8:32 am
I've been told in UK you can buy hardened steel caps to sit over the valves for the rollers to run on.
Not sure if they are for stock 7/32" valve stems, or the 6mm stem race ones...
PostPosted: Wed May 07, 2014 8:35 am
That's gotta mess with the geometry a bit? (valve height)
http://www.mini-hb.co.nz
PostPosted: Wed May 07, 2014 8:37 am
Nah you just shim the rockers up.
GR and Minis Plus both sell laser cut shims.
PostPosted: Wed May 07, 2014 8:28 pm
How does the cap stay in place? Loctite? Or is there enough of the stem before the collet?
5/72 Clubman Gt
PostPosted: Wed May 07, 2014 9:18 pm
It sits over the stem and clear of the collet. Same as valve shims on an Alfa etc do.
PostPosted: Thu May 15, 2014 2:45 pm
I found this article.
http://www.racetechmag.com/features-1/l ... stems.html
