It is currently Tue Jul 22, 2025 7:39 pm
PostPosted: Mon Apr 21, 2014 10:14 am
Hi all you Mk 1 S owners,
I've noticed that the engine block stampings on our cars have a mixture of either the upper case "A", or the lower case "a' included in the 6mm stamped 9F/Sa(A)/Y ****. These blocks were restamped by BMC after the riveted tag with the original engine number was removed to satisfy the Aussie Authorities, (the tags all had the lower case "a").
I have two engine blocks only 5 numbers apart & they are both most definitely stamped with the same set of 6mm punches & include the "A", but I note that on two 1965 cars I know of, the blocks are stamped with the lower case "a".
Checking around here with my Mini colleagues it would appear that the later cars were factory stamped with the upper case "A", so could any one solve this riddle? - I'd be happy to collate a list of cars by build date & whether they have "a" or "A" so please check you block stampings & let us know?.
If you are unsure of the build date, maybe the car number?
BTW, The two blocks I have haven't been re decked!
Thanks for humouring this Mini tragic with OCD....
PostPosted: Mon Apr 21, 2014 10:29 am
My Mk1 S was a 1968, it was 9F/SA/Y prefix. Upper case...
[edits] I have another ausmini member's Mk1 motor here at the moment, it is also 9F/SA/Y prefix and the stamping looks original, it has been decked a little.
Last edited by drmini in aust on Mon Apr 21, 2014 1:58 pm, edited 3 times in total.
PostPosted: Mon Apr 21, 2014 11:47 am
ooops have corrected that
My 'S' is a late 1967 and has the large 'A' on the block and small 'a' on the ID plate
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Apr 21, 2014 12:33 pm
I have an early 69 Mk1 with Large "A" on the engine block and small "a" on the ID Plate.
My engine is 60thou over so I think you would get a more accurate database using STD engines as a reference.
I would expect that my engine has been decked at some point in its life.
PostPosted: Mon Apr 21, 2014 4:21 pm
The ID plate stamps are interesting. It seems that they didn't buy a small "a" till they were in the 4000s on the Cooper. I would guess 64.
All the Cooper S ID plates I have seen have a small "a" and that goes for the Deluxe, Morris 1100, Austin Freeway, Wolseley 24/80 etc. as well.
The factory did use a small "a" on engine blocks. The Morris 1100 blocks have a small "a" and I would assume the Deluxe got it as well.
My Cooper S has a big "A", I don't think it has been restamped. If they were going to stamp it they would have done a better job.
PostPosted: Mon Apr 21, 2014 6:28 pm
So far, so good!
PostPosted: Mon Apr 21, 2014 6:54 pm
To my eye it appears that the locally assembled motors had the numbers stamped with a tool that held all the digits and the imported motors were stamped one digit at a time.
PostPosted: Mon Apr 21, 2014 7:31 pm
So which ones are Fakes?
"Let us remove your "SHORTS"
PostPosted: Mon Apr 21, 2014 8:34 pm
What is the reason/meaning behind the use of the lower case a?
PostPosted: Mon Apr 21, 2014 8:36 pm
Mine is also upper case on the block and lower case on the ID plate. 68 Cooper S. I don't believe it has been re stamped.
PostPosted: Mon Apr 21, 2014 8:49 pm
At a guess, so it didn't get confused with the other 'A's that were in regular use in the codes.
A = Automatic
a = Remote control centre change gearshift (always preceded by an S or a T)
S = close ratio
T = standard ratio
U = Centre change
PostPosted: Mon Apr 21, 2014 8:51 pm
Are they in a perfect straight line or do the vary a little?
PostPosted: Mon Apr 21, 2014 8:54 pm
Thanks for the explanation, and no mine are not straight they vary slightly.
PostPosted: Tue Apr 22, 2014 7:30 am
Hi
in my collection.. no idea of build date, however numbers for your reference
PostPosted: Tue Apr 22, 2014 12:22 pm
This block looks to be about october 1965, so that would back up the theory that only the early (1965) cars were stamped with the lower case "a"..
Thanks for the info!
