It is currently Sat Jul 26, 2025 10:23 pm
PostPosted: Fri May 13, 2005 11:02 pm
Hi.
Spotted a 850 morris FS and was wondering if my 998cc engine/gearbox from my moke would be a simple bolt in or is there any modifications required?
cheers.
Shard
PostPosted: Fri May 13, 2005 11:07 pm
there shouldnt be any mods, the mounting points are all the same i think, my car had a 998 wen we got it so im sure it can be done
sean
Potato
PostPosted: Fri May 13, 2005 11:08 pm
Pull the old one out and just put the 998 in...just check for electronic's and axle connection....2 weeks just in case :wink:
PostPosted: Fri May 13, 2005 11:10 pm
Awesome :D.
Yeah I'll probably need more time then two weeks. WIll make a nice winter break project if I get it.
Gunna ring up tommorow and find out if it's still available then pop down have a look before deciding. Here's hoping.
*goes to bed with the excited feeling only a new mini can bring*
Shard
PostPosted: Fri May 13, 2005 11:24 pm
Mate :D if you are looking a winter project...Excellent...how much are you paying for the engine...
Additionaly can you adjust your Profile with where you Live..It does also help Us to help you with aditional info with contacts or locals on Ausmini can come around and say Hi and have a look what you have... :wink:
Specialy handy if you have not puller an engine or put one together :!:
PostPosted: Fri May 13, 2005 11:33 pm
if the 850 has a "magic wand" gearstick you might have to cut a hole for the remote one that the 998 will have.
PostPosted: Fri May 13, 2005 11:39 pm
Done. I remember doing the profile stuff when I first joined.. must have gotten lost maybe in the forum address change *looks around*.
The donor motor will be from my current moke. It's seen better days (engine is fine though) and I want to change over to a mini, the bug resurfaced a few months ago so I've been keeping my eyes open (especially with tax time just around the corner). Got no idea what condition the current motor is in the car i'm interested in, but for the price it's probably not too good.
Not sure what a remote gearstick is. My 998 has a big wand looking like gearstick coming out of the floor panel. The original knob was a little black cylinder type one making the stick look like a wand, is that the wand or remote type?
Shard
PostPosted: Fri May 13, 2005 11:42 pm
True but what a differance the engine would be and full sycro box also :wink:
you could also go a 1100
PostPosted: Sat May 14, 2005 12:44 pm
a remote or rod change will come out of the floor here, as opposed to a "magic wand" or "pudding stirrer" gearchange which will come out at the floor where it meets the firewall.
the 850 doesnt have a hole for this unless someone has already modified it.
PostPosted: Sat May 14, 2005 4:35 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
also you will need a mini rod change mech as the moke one is shorter
makka
PostPosted: Sat May 14, 2005 8:11 pm
a tip from a couple of guys that have done it is to take a template of the floorpan of a mini with a remote change gearbox and use that to mark out the hole. this will make it look a lot more factory, as most are real butcher job.
an alternative is to stick the 998cc engine on the 850 gearbox, or the 850 diff housing on the 998cc gearbox. the latter is what is in my 850 at the moment, and it works just fine.
i would recommend you go for the remote change if you want to drive it in a spirited manner, as the engine is far more stable with the remote change.
michael
PostPosted: Sat May 14, 2005 9:16 pm
michael
Yeah the good old 850 box is about as well located (NOT) as a rod change is.. :lol:
PostPosted: Sun May 15, 2005 8:55 am
you'll end up with something like this.....if you're dodgy :)
Image[/img]
PostPosted: Sun May 15, 2005 8:42 pm
Thanks for the info guys. Rang up 9am Saturday and it was already gone :evil:.
Going to have to start scouting the TP Thursday mornings I think. To top it off my steerings decided to start slacking just enough to be annoying out of the blue. Had a new steering rack put in by nrthern late last year too grr.
Shard
