It is currently Mon Aug 04, 2025 5:55 pm
 Post subject: Boot Badge Font
PostPosted: Sat May 03, 2014 10:33 pm
I want to get some additional badges made up for the boot of the Mini, to match the existing ones.
Anyone know what font the standard badges are? - eg the Morris Mini Deluxe or Morris Cooper
I will have them laser cut and milled to look the same.
 Post subject: Re: Boot Badge Font
PostPosted: Sat May 03, 2014 10:55 pm
I worked it out recently, but you probably won't like the answer (which I've temporarily forgotten). The font was heavily modified for the badges, it is bolder and manually kerned (by the bloke who filed the originals out of brass). To get a computer generated font to be an exact match is a lot of work. I'll try to track down what I worked it out to be.
Alternatively you can try to work it out yourself. These sites are really helpful: http://www.identifont.com/identify.html
http://www.myfonts.com/WhatTheFont/
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun May 04, 2014 5:15 pm
Wouldn't it be easier and cheaper just to buy new repro badges.... Just saying :)
PostPosted: Sun May 04, 2014 5:24 pm
mate of mine got some badges printed in plastic by shapeways.com and then chromed, I haven't seen them but apparently they turned out really well - less than $50 for the printing
only if you want it to say something that's already been said....
PostPosted: Sun May 04, 2014 5:29 pm
Ok I get it now, custom script :) apologies
PostPosted: Sun May 04, 2014 5:36 pm
http://www.identifont.com/show?4E1
http://www.identifont.com/show?7OD
PostPosted: Sun May 04, 2014 7:25 pm
Hi Simon, Tim,
Thanks for the links, and try.
I will try and get a Matic badge. That will give me most of the letters I am looking for. All except the W in Twini.
Fortunately all the letters are capitals.
PostPosted: Sun May 04, 2014 10:17 pm
Yeah W is tricky. That font was used for a lot of different words but I can't think of any with a W.
Mark Forster from the Mk1 Forum in the UK had a custom made badge done for his Mini Sprint. It looked really good.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Mon May 05, 2014 9:54 am
This is the closest I could find. Its called Rockwell Bold and is pretty much identical to the font used by Morris before the BMC merger. It was mainly used for things like titles in brochures and the covers of manuals - sort of a corporate identity. I'm pretty sure this font was used on the Morris Minor badges, then the Morris Mini got a slightly squashed bolder version of it. If you're keen you should be able to use it as a starting point and squash it a bit. At least it shows what a W would look like.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Mon May 05, 2014 1:22 pm
Try COOPER BLACK which comes standard with Microsoft word, its pretty close
PostPosted: Wed May 07, 2014 10:55 am
This txt style it should be the one. Clarendon Text Bold SCOsF
PostPosted: Wed May 07, 2014 1:38 pm
I reckon Blackoak Std is the closest I've seen - http://fontzone.net/font-details/blackoakstd - go to preview, and type in MORRIS. The R's need their tails cut off and the rest of it fattened up, but it's pretty close
PostPosted: Sat May 10, 2014 9:57 am
Why don't you employ a graphic designer to do you a vector image of what you are after?
Surely there is someone on here that wouldn't mind a carton of beer!
(Or do we have nobody proficient in Illustrator?!)
PostPosted: Sat May 10, 2014 8:13 pm
Or do it yourself for free in Inkscape.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Sat May 10, 2014 8:35 pm
Hey Indigo, What would you like typed out, I'll lay it out for you as vector in a few fonts to match.
Users browsing this forum: Bing [Bot] and 106 guests
