It is currently Mon Jul 28, 2025 3:45 am
 Post subject: A+ Distributors
PostPosted: Mon May 05, 2014 2:19 pm
What's the best buy for A+. I'm currently running a Nissan conversion, but have had some trouble. I've got a standard A+ on at the moment and I can get the car to run, while I have the Pulsar dizzy checked. If I'm to commit to another A+ type as the current is on loan, what the best advice?
What about the 59D Powerspark?
http://www.ebay.com.au/itm/Mini-MKI-1000-1300-A-Points-Distributor-59D-by-Powerspark-/360661531027?pt=AU_Car_Parts_Accessories&hash=item53f91a3993&_uhb=1
 Post subject: Re: A+ Distributors
PostPosted: Wed May 07, 2014 9:21 am
No takers?
PostPosted: Wed May 07, 2014 9:54 am
I'd take one of those from Simon BBC, but get it with an electronic module in it, and no vac advance if running a Weber. :wink:
Also watch how much centrifugal advance it has, many aftermarket dizzies have too much. With your modified cam etc you only need around 9deg at the advance plate, advance all in by 4000rpm or sooner.
That is 18 deg at the crank, so @ 30 deg total advance (~the usual) you would have about 12 deg static timing.
PostPosted: Wed May 07, 2014 5:11 pm
Imho I would get one graphed for your engine spec.
I got Graham Russell to do my metro A+ one and I have just re done my one in my Moke myself
There are quite a few books about on the subject and the Internet is a treasure chest of knowledge.
I cannot see how you can guarantee a successful out come if you just buy off buy the shelf
Kiwiinwgtn
PostPosted: Wed May 07, 2014 5:48 pm
GR dynoed a 1360 for an ausmini member last week, the chinese made dizzy was still advancing at 6200 engine rpm!
HP was good but it would be better down low after the dizzy curve gets fixed.
PostPosted: Wed May 07, 2014 7:31 pm
Yes, the one I sourced from the UK also had to be re-graphed as it had 40* IN THE DIZZY and was still advancing when checked on the dizzy machine :shock: :shock: :shock:
These dizzy's should be added to the New Parts - Rubbish list.
Steve
PostPosted: Wed May 07, 2014 7:39 pm
I put a Stealth Blackbox under my dash. It sits in series with the -ve coil to dizzy wire.
Any advance you please as well as dwell. No more dizzy calibrations, and it runs a low low resistance coil.
Putting it in was a bit of a learning curve for me wrt dizzy timing, but quite straight forward fit out.
viewtopic.php?f=2&t=83483
PostPosted: Wed May 07, 2014 9:12 pm
Mick can you get them here yet or need to import? I want one... 8)
PostPosted: Wed May 07, 2014 9:14 pm
I got mine from Rob Roy Historic Spares in Melbourne. He's on eBay as well.
$188 each. Cheaper than a rebuild and recurve.
http://www.robroyhistoricgarage.com.au/ ... pares.html
http://www.ebay.com.au/itm/Stealth-Blac ... 2339907df6
Also I suppose you should need a module for the dizzy if you still run points, no reason I can understand why you HAVE to, its just an on off switch after all...but you can remove the the majority of the remnant scatter that way. They sell them as well.
PostPosted: Wed May 07, 2014 9:27 pm
Thanks Mick. Just ordered, they are $190 now.
PostPosted: Wed May 07, 2014 9:32 pm
That's CPI for ya...
Might get it by Friday with a bit of luck?
Let me know how you go.
PostPosted: Wed May 07, 2014 9:35 pm
eBay link-
http://www.ebay.com.au/itm/Stealth-Blac ... 1286055616
They are 145 QUID in UK. :shock:
http://www.ebay.com.au/itm/like/1512860 ... e&lpid=107
Last edited by drmini in aust on Wed May 07, 2014 10:00 pm, edited 1 time in total.
PostPosted: Wed May 07, 2014 9:36 pm
I know! That is very odd. They're only a little cheaper than here in the US as well.
PostPosted: Wed May 07, 2014 9:43 pm
Or the same one here for $2000
http://www.ebay.com.au/itm/Electronic-i ... 2a2bf3c161
PostPosted: Wed May 07, 2014 9:52 pm
Yay for Australia!?
Users browsing this forum: Majestic-12 [Bot] and 81 guests
