It is currently Fri Aug 08, 2025 2:53 pm
PostPosted: Mon May 05, 2014 5:31 pm
I'm away from home and can't access the material that would answer this question that was asked by a colleague. Hopefully Morris 1100 is not far away. :wink:
PostPosted: Mon May 05, 2014 6:25 pm
Sorry to say I don't really have a full answer for that one. The XE somehow refers to a 4 syncro gearbox.
All the Cooper S codes are silly. Sticking a 9 in front of them to try and fool the FIA that the 1275 is really a continuation of the 997.
PostPosted: Mon May 05, 2014 6:51 pm
p71 of John Parnell's book "Original Mini Cooper and Cooper S" just states `Introduction of 4 speed all-synchromesh gearbox'.
PostPosted: Tue May 06, 2014 8:47 am
The XE means its a 4 synchro close ratio box ie Cooper S ratios.
When you compare it to the 3 synchro Ta/Sa boxes where the T means standard ratio and the S means close ratio/Cooper S and the a means 3 synchro, then the X probably refers to close ratio and the E means 4 synchro box.
RonR
68 build Mk1 Cooper S
PostPosted: Tue May 06, 2014 3:42 pm
the gearbox case should have XE stamped on the front too
